Question about Whirlpool ET8CHEXSQ Dryer
My gas whirlpool dryer has been converted to propane. I need to convert it back to natural gas. I still have the orifices for the natural gas hook up. What is the easiest way to switch the orifices.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Dissasemble the old ones for the new ones.
turn gas off first, and the ignitor, power off.
Vitally
Posted on May 15, 2009
How to convert a whirlpool dryer from natural gas to propane gas
Dryer should have come with a bag of orifices with instructions. If not, ask dealer. Switch out orifice (threaded brass fitting with a small hole) in the dryer's gas valve and and adjust regulator (threaded screw or knob) on the valve according to instructions.
Oct 17, 2014 | Dryers
Maytag neptune gas dryer Model # P MD64000AWW converting to propane and would like to convert back to natural gas
NEED TO CHANGE GAS ORIFICE. THEY ARE DIFF. BETWEEN NATURAL GAS AND PROPAIN THATS ALL YOU HAVE TO DO.
Oct 06, 2013 | Maytag Neptune MCG8000AW Gas Dryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
Need book to convert dryer from natural to lp
Thank you for contacting Fixya.com.
Please check the bellow links to have an in-depth knowledge related to your query:-
http://www.ehow.com/how_5321294_convert-dryer-natural-gas-propane.html
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Whirlpool Dryers
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
Converting propane to natural gas
hi there..be advised do not attempt this conversion yourself....legislation requires you have this work carried out by a corgi registered gas engineer who will issue you a certificate for you home insurance......NO CERTIFICATE NO INSURANCE..&..YOU ARE PUTTING YOUR LIFE AND OTHERS AT RISK ..
Sir Galahad
Aug 24, 2009 | Dryers
Convert propane dryer to natual gas
You need the NAT gas orifice and the stem under the cap on the burner needs flipped over
Jun 08, 2009 | Whirlpool GGX9868J Gas Dryer
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whirlpool ET8CHEXSQ Dryer Logo
202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
