Question about Frigidaire ATF6000ES Front Load Washer
Washer smells have tried wiping the rubber ring and dealer sold s
I have a front load washer for a couple of years now. I can not believe the smell that comes out of the washer now. We wipe the rubber off and check for stuff that might be in there nothing dealer sold us some little white balls thats supose to help ha ha
  • cchristman1 May 14, 2009
    The rubber has mildew on it and it smells, I have to leave the door open after I do the wash to let air dry it out. I have also been using bleach to clean the rubber ring.
  • 323 Answers
You may find it hard to believe, but most newer front load washers have this problem after being in use for a while. Mine is a GE, and they have the worst reputation according to owner forums.
So here's the fix:
First, I assume you know that little pieces of stuff build up under that rubber ring at the bottom. You need to clean that out with 50% bleach and 50% water. Occasionally it doesn't hurt to run a quick wash without detergent through the machine empty. Add bleach liberally to the water. After it is done, leave the door open a crack to allow it to dry.
It's the nature of the beast!
Sirwriter
Posted on May 14, 2009
I had the same problem, and I fixed it very easily. I switched to powdered detergent. I have completely stopped using liquid detergent, and the problem has vanished!! Give it a try. I used Tide HE powder.
Posted on Jun 15, 2009
    Problem Solver:
  • 12 Answers
Typically the smell is actually from the inside of the unit which you can not reach physically with out serious time invested.
The smell typically is the tub internal as water is never actually completely out of the unit and it will build up over time, within the tub as well as in the water since the coin trap with in the tub to drain connector will build up with hair detergent and fabric softener.
2 steps can be taken:
1) open the service panel in the rear of the unit, down at the bottom there is the tubing that comes off the tub facing straight down, going to the drain and to pressure sensor switch.
Open and clean. Make sure to match up arrow on tubing with tub. tighten tightly as the movement while washing may cause this to come off if not tightened enough.
2) Start unit in a normal or sanitary allow to fill with water and start to agitate. (No clothes) Open soap dispenser and pour 2 cups of "Distilled White Vinegar" allow to run through full cycle. Once completed open door to air out and wipe down rubber boot seal. Repeat 2x monthly for first month. then 1x per month therefore after. This will break down detergent and sediment on outer tub.
Hope this helps.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
I agree with Bboyabs. I cleaned the seal, ran it through a wash with bleach only, and switched from liquid to powder detergent which I think helped the most. The clothes smell fresh again.
How do we deodorize a smelly front load washer?
Buy the washing machine cleaning products near the laundry soaps. I believe Tide sells one.
Aug 09, 2014 | Frigidaire Washing Machines
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We've had our HE 2 plus washer for a couple years, and we have started to smell a slight mildew odor. Is there a trap someplace that needs to be cleaned, or something else I need to be looking for?
You need to use some bleach and clean the washer out. I also wipe the rubber around the door opening and leave the door open airing out the machine. The rubber gasket will grow black mold.
Aug 13, 2009 | Kenmore HE2 Plus Front Load Washer
I have an older front loading washer Frigidaire and it's now smelling like mold on all our clothes thought it was me leaving clothes in to long but it's not. model #FWT445GES2 serial #XC74463636 . I have...
No recall, Pour 2 cups of bleach into the washer, Wash on HOT water, long cycle. Then wipe seal with dry cloth. This will eliminate the mold smell... To stop it from coming back ALL front load washer doors MUST be left open to allow the rubber seal to dry, Just like you close your shower curtain so it doesn't get musty smelling... 2 hours is about the dry time... wiping the seal with a cloth usually helps too... All located in your owners manual/
Jul 31, 2009 | Washing Machines
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Mold & Smelly in Washer
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
dundat45
Jul 19, 2008 | Whirlpool GHW9100L Front Load Washer
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
240 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
