Question about Samsung DLP HL-P5663W 56" TV
Just changed color wheel on the DLand red temp light is blinking
I just changed the color wheel and the red temp light is blinking and the DLP is not turning on. What could this be. I have heard that there is a sensor of some sort but I can't find anything like this.
    President:
  • 814 Answers
For technical help from samsung just plug this web address in to your address bar. http://www.samsung.com/us/info/contactus.html# Pick the DLP television section and put in your model number and fill out the form for technical assistance. Or you can call this number for telephone assistance 1-800-726-7864. Hope this helps you with your problem.
Posted on May 17, 2009
  • krimi Aug 11, 2011
    It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Jul 27, 2011 | Dell 1409X DLP Projector
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
The tv will not come on . The power led is blinking 3 greens and then 2 reds. I have changed the light but still can not get the tv to do anything. I can't even shut the power off with the buttons.
Most likely its not the lamp thats bad but the color wheel is stuck. Check if the color wheel starts or not. You can make this out from the typical dlp switching on whine. If you have already changed the lamp, and there is no color wheel start noise, you have a bad color wheel.
Aug 28, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
487 people viewed this question
Henry  Thomas
Henry Thomas
