Question about Peavey 32fx USB 32 Channel Mixer
Using the USB connection to send the stereo mix to a computer
I have attempted to use the USB connection on a Peavey 32FX mixer to send the stereo mix to a computer for input to REAPER for recording. Reaper recognizes the Peavey mixer and I can select it, but no sound seems to get to the program. How can I activate the sound? Thanks.
  • Daz Lewis
    Daz Lewis May 11, 2010
    Have your tried updating the Peavey software on the desk itself? You can get up to date firmware upgrade from the Peavey website. This tends to solve a lot of problems with this model desk. Can you record direct to a flash drive plugged into the USB port? If not this could suggest a faulty USB port.
    Problem Solver:
  • 5 Answers
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
Posted on Aug 02, 2009
How do I fix my mixer 32fx out put
If the mixer output shuts down as you describe, some part is over heating and once it cools down you can turn it back until it happens again. This will not be user serviceable. Here is the link to Peavey Support who can provide a service center contact and schematics.
peavey com
May 21, 2016 | Peavey 32fx USB 32 Channel Mixer
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
How connect nuendo to PV mixer?
well you will have to look in your computer, then the program, and then find audio properties and look for the peavey ASIO driver and connect.
May 29, 2014 | Peavey 32fx USB 32 Channel Mixer
I have the peavey xr 8600 and i wanna know how to connect an additional non powerd mixer to it ( i wanna use the peavey as an amp??
That's easily done. Simply connect the left(or right) output of your mixer to one of the channels on the peavey. Use any line input. Since the peavey is a mono system, there's no need sending a stereo mix to it.
Mar 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working but the audio continues to be routed to the lr outputs. The channel level can the...
If your setup depends on the USB to the computer, I suspect the problem is in the computer, possibly a throughput probllem if you have antio-virus programs running. They take a lot of throughput and often come in at random times.
If you happen to be using a PC with this, check the usage of computer resources from the process listing.
May 15, 2010 | Peavey 32fx USB 32 Channel Mixer
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working, but the audio continues to be routed to the LR outputs. The channel level can the...
Try performing a full firmware re-install, or update if your not already on the current firmware. Click on the "Downloads" tab to access the latest firmware. http://www.peavey.com/products/browse.cfm/action/detail/item/116194/32FX™.cfm
Mar 29, 2010 | Peavey 32fx USB 32 Channel Mixer
How do I connect monitors?
You run one or more of the AUX outputs to an amplifier then to a passive monitor, OR if you have powered monitors then you just run the AUX's as needed to the powered monitor(s)
You then adjust the "AUX" mix for each channel input to each of the AUX you are using for the monitors as needed.
Mar 19, 2010 | Peavey 32fx USB 32 Channel Mixer
Peavey 32fx USB 32 Channel Mixer Logo
602 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
