Question about Toshiba Satellite A205-S4617 Notebook
I have a toshiba satellite 2210 and i want to
I have a toshiba satellite 2210 and i want to connect it to an ordinary tv set what cable should i use and how? It has only aport for lcd.
  • Frank Zhang
    Frank Zhang May 11, 2010
    so you want connect to both LCD monitor and TV?
    what model and port S-PORT//AV PORT//VGA PORT at your TV ??
    Scholar:
  • 70 Answers
Check your TV set to see if it also has a VGA port on it, and if it does, then you can use a standard VGA to VGA cable. If not, then your best bet may be to see if you can get a hold of a VGA to Video-in cable (also called RCA). The Video-in cable will be a single thick pin, usually yellow in colour to match its corresponding port on the back of the TV. Now bear in mind that this will only carry the video signal, it will not carry the audio signal (you would need a 3.5mm to RCA cable to go from teh headphone jack on your laptop, to the red and white connections on the back of the tv. Hope this helps!
Posted on May 14, 2009
  • 221 Answers
You'll need to go to a store and find a converter cable. Honestly, most stores won't carry something like this, but it's possible that you'll find one. I found a bunch on eBay. Here's an example of what you're looking for. They come in a wide range of quality and prices, but this is basically what you're looking for. If you wanted a really high quality one, you should go for an actual converter device, and not just a cable where "magic" happens inside. Here's one I found:
http://cgi.ebay.com/VGA-to-TV-S-Video-RCA-AV-OUT-Converter-Adapter-Cable_W0QQitemZ250417764135QQcmdZViewItemQQptZPCA_Cables_Adapters?hash=item3a4e0fd727&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1308%7C301%3A1%7C293%3A1%7C294%3A50
When i mak the automatical programin for my tv (toshiba model no. CN27H95) it find nothing!!!! so there are others ways to mak manual programing to find chanels?
This feature is pretty reliable and the lack of channels may be due to the lack of signal to the set.
You must have either an antenna, a cable from a cable service or a satellite receiver connected for the set to find any channels.
Oct 24, 2014 | Toshiba CN27H95 27" TV
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Jan 18, 2013 | Toshiba Satellite L675-S7044 Notebook
Connect TOSHIBA SATELLITE A205-S5855 Laptop to TOSHIBA 40H80 TV
You can use the VGA cable which has 15 pins at both ends. For sound, you will need mini stereo phone plug at both ends.
You will have to use the combo key Fn and either F5, 6, or 7 to select the internal, external, both.
Make sure to set the video resolution to the native resolution of this TV otherwise you will get 'Format nor supported' on the screen.
http://s807.photobucket.com/home/budm/allalbums
Jul 02, 2010 | Gateway FPD2275W LCD Monitor
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Connectiing toshiba satellite 2210 to a tv set
The cord you need will either be VGA to S-Video or VGA to RCA depending on which port is on the tv.Once you have the cord hooked up to both,You will need to switch into presentation mode on the laptop using the FN + F7 keys.
Please take time to rate this fixya
May 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Cable connection
Just go to the dollar store buy new cable connector adapter it fits on end of cable so you can plug in & out / without breaking IF connector on tuner.
Aug 26, 2008 | Toshiba MD9DM3 9 in. TV/DVD Combo
Tv model 42H82
Hi Ranger01,
If you satellite receiver is HD, connect it to your audio system with Component or HDMI (preferred) cable. If your receiver only passes through HDMI, you will have to use an optical toslink cable for digital audio.Have the monitor out (HDMI or Component) go to one of your tv inputs. Set your TV to Mute and program the satellite box to out put audio through the appropriate cable (HDMI, component or Toslink optical). More details as to brand/HD tv or not will help me give you a more specific answer.
Hope this helps,
Regards,
Machaan
May 31, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba 36a41 television
You should be able to use your remote control to do this.Your channel 73 is more than likely UHF 73 so you need to put your tv in the antenna setting rather than cable setting. Once you do this just input 73 with your remote. Hope this helps! Stargazer
Jan 21, 2007 | Sony KV-36XBR250 TV
Toshiba Satellite A205-S4617 Notebook Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
