Question about Alpine Car Audio & Video
I need to find out the weiring diagrame to install it
    Problem Solver:
  • 11 Answers
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
I need to find out the weiring diagrame to install - 3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
Posted on May 14, 2009
Top half of freezer not freezing?
ok the thing you need to go if check all the weirs and make that they are all pluged in all the way...if that dont work then the weirs may have a short in them and the only way you can fix that is to by a new freezer
Dec 03, 2015 | Refrigerators
I have a 49cc Yuma 4wheeler I need a weiring diagram for
Your question is wrong. I beleive it is Yamaha not Yuma And you need to specify the exact model number and year if you want answer to this question.
Oct 13, 2014 | Motorcycles
How do I replace the Hayward sp1070
Good Day, this is John the Hayward tech. I have attached a link to the SP-1070 skimmer. The weir is replaced by removing a screw from inside the front of the throat of the skimmer. This removes the plate the weir is attached to. You can also just pop out the weir without removing this plate by gently bending the plate at one end and removing the weir pins from the plate. http://www.hayward-pool.com/pdf/manuals/Automatic-Surface-Skimmer-SP1071-SP1070.pdf
Aug 30, 2014 | Hayward SP1070 SkimMaster Auto Skim Series...
I have a 2000 jeep cheroke and keep blowing a fuse in the fuel injection circuit durin g cranking. I need a wiring diagram for this circuit
i wold look around the top engine .by are filter.or follow your cranking weir from starter bakwords maybe to relay look for chafing.what Sta's hot Will cranking coil distributor.or unplug one injector at a time and try this wold be my last try. try using breaker not heavy jumper weir have sum one tap the key will you watch and liston around the top of engine.be Shir your in park has anybody dun anything to it recently look there.
Jan 25, 2010 | 2000 Jeep Cherokee
Need a weiring diagram
go to the manufactures website or go to a best buy or jo dies they can help
Jan 08, 2010 | Fusion FEW12PK Car Subwoofer
My truck wont move in drive and third
If you are not hearing any weired noises coming from the trans you may have a burned out or bad solinoid. Have someone trace the wiring diagram to determin which solinoid supposed to kick in when shifting to drive. Open the cover to the solinoids, locate and test it.
I hope this helps.
Sam
May 13, 2009 | 2003 Chevrolet Silverado 1500
I have takend the weiring off of my 125 yamaha dt what wires do i need just to start the bike
alrite mate i had the same problem if you go to www.dtr125.net there is a wirein diagram on there
May 07, 2009 | 2000 Yamaha DT 125 R
Chevy blazer tahoe v6 4.3 vortec won't even give me a light
any losen weire araund starter?on starter hawe 3gray fusebel link weire and hawe to conect with same weire from batt big red weire.if are conected chek gray 3 weire by sleigty poling on weire and see if is brocken samtime brick iseide under insolation and yu cant see disconect batt before inspection
Mar 12, 2009 | 1993 Chevrolet S-10 Blazer
Typewriter just beeps
very common problem, The print wheel homing sensore weirs broke off. you need to take off the ribbon deck. pull weirs from the white plastic sleeve that runs from carrier to main board. fined 3 weirs grouped together ( red, black,green) 1 or more of them are cracked in side the casing or have broke in 1/2. need to resolder them together little tough to do the 1st time. a bunch of sen sores came out with to hard of a weir making them brake premacherly
Jan 08, 2009 | Nakajima AE-710 Typewriter
Im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
Jun 21, 2008 | Kenwood KDC-128 CD Player
Car Audio & Video Logo
477 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
