Question about HP Officejet Pro L7780 All-In-One InkJet Printer
My faxes would not feed straight.
I looked in the (upper) document feeder and I removed a plastic piece (blue) from somewhere. Now my documents do not automatically feed! trouble is, I cannot remember where this piece was originally placed. It did not break, I just can't seem to fit it back in.
The piece is narrow, with "teeth" like projections on one side and two 3 prong claw like projections on the opposite side.
Any ideas?
    Problem Solver:
  • 5 Answers
Refer the link below. you will be able to fix the blue plastic piece
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01110425&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on May 14, 2009
Line thru the documents when using top feeder
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
hth,
razors
Nov 28, 2011 | Brother Office Equipment & Supplies
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
My printer jammed while trying to fax a legal document. It said to clear the feeder, which I did, by lifting the cover and pulling the document through. It continues to give the error message that there is...
Here's what I think you need to do. 1 Open the top cover. 2 You will see a roller assembly. 3 rotate the assy up so its pointing up. 4 Remove the spring. 5 the roller assy will now lift out. (note how it came out.) 6 you will now see a green piece of plastic on the left. 7 Remove the green plastic and see if any paper is there. (note how the green piece came out.) 8 Re assemble and test. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 2820 Printer
How do i fax multi pages at once
Your document feeder should allow you it install a stack of originals, amount depends on machine specifications. Dial one number and send your multi-page document.
if not the feeder tires may need to be cleaned, a few drops of alcohol in the center of a clean piece of paper then run it through the feeder, put the paper in then when it stops press the stop button and it should eject the document, in doing so pass the alcohol past the feed tires. do this a couple of times then try your multi-page document again.
Hope this helps
Ed
May 04, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
"Check Document" message
look for a switch trapped down in the document feeder
Jan 28, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Mar 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Document feeder jam?
So when you copy via docfeeder, everything comes out fine?
Look around where the paper exits the docfeeder...there should be some kind of black plastic flapping piece...the paper pushes it up as it goes through the machine.  If this is stuck up, the docfeeder might think that the paper is stuck inside the feeder.
Oct 27, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Sharp F0-1460
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Jul 13, 2007 | Pitney Bowes 9920 Plain Paper Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
