Question about Medion (MT8381) (40004683) Motherboard
Ummm hey i bought a Galaxy GEFORCE FX 5500 256mb 128 bit AGP
Video card and i try to put it in my p4mm2 motherboard but when i start.. it wont open do you think they are not compatible?... cause when i use my old one it starts.. help plsss tnx
  • 1 more comment
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Did you install the driver for your new card?
  • joecoolvette
    joecoolvette May 11, 2010
    I just looked up all versions of the ECS P4MM2 motherboard, and they all use an AGP 4X expansion slot, for a graphics card. What Galaxy GeForce graphics card are you trying to install?
    BEFORE you installed the graphics card, did you install the Drivers? They come on a CD disk with the graphics card.
    One last thing, and this is not to offend you in any way. Do you have the monitor cable plugged into the graphics card? Sometimes we get a little zealous when building a computer.
    Lastly, the BIOS of your motherboard may need an update. IF, there is a BIOS Update available.
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats old card? onboard or AGPslot? what model your new card?
HP GeForce FX 5200, AGP Graphic Card fit the slot in my HP Pavilion Slimline s3620f
No this card won't work in an 'HP Pav. Slimline s3620f" The specs from HP say it has one open PCI-E slot that is used for graphics cards.
Jul 09, 2010 | HP GeForce FX 5200, (128 MB) AGP Graphic...
\date of release ATI RADEON 9550, AGP Graphic Card
December 2004, I have the exact one in my system.
Nov 19, 2009 | ATI RADEON 9550 Graphic Card
Is DFI AK75-AL compatible with 128Mb/128 bit video card?
Yes, the DFI AK75-AL motherboard has a VIA KT-133A chipset which is compatible with a FX5200 videocard, but not at the full 8x AGP speed (as the videocards supports) but only at 4x AGP speed (maximum speed supported by the motherboard).
PS: Make sure you use the newest motherboard BIOS en VIA chipset drivers to ensure compability.
Apr 09, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
I have a Geforce Fx 5200 graphics card would like to up grade
the motherboard supports only APG graphic crads, as long as you can get AGP your are fine. there are several brands in the market. so i suggest you have a look at the link below.
1. http://www.ngohq.com/home.php?page=Articles&go=read&arc_id=116
Feb 25, 2009 | XFX GeForce FX 5200, Graphic Card
I lost the cd for my graphic card and cannot for life of me find on internet, here is card type : pny geforce fx 5500 ddr 128 mg agp.. anyone have a free driver ?
I don't, but Nvidia does at http://www.nvidia.com/Download/index.aspx
you have a geforce 5 fx.select your os and language. this will give you the unified driver that works on all Nvidia chipsets. be advised the card you bought was private labled to PNY so the automated driver search will probably just tell you you don't have any Nvidia cards installed.
Feb 24, 2009 | PNY Verto GeForce FX 5500 PCI, (128 MB)...
Problem with k7s41GX
try to check your RAM.. maybe your ram is LOSE connection or physically damaged.
Feb 04, 2009 | Asrock K7S41GX Motherboard
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
Can i upgrade my fx 5500
ya u can pci right so u want best buiggest pci card u can get wich aint much more fx 5700 i think fastest they make pull it out put new one in
Jan 27, 2008 | Palit Microsystems GeForce FX5500, (256...
AGP video Board recommended for PC Chips M925 V7.3
FOR YOUR MOTHERBOARD , ITS BETTER TRY NVIDIA GEFORCE CARDS LIKE GEFORCE MX4000 , FX 5200 , 5500 , 6300 BUT DONT USE SLI CARDS , THEN ABOUT YOUR ASUS RADEON ITS ADVICED THAT ASUS RADEON 9200 WILL WORK BETTER WITH INTEL MOTHERBOARDS
Aug 23, 2007 | PC Chips (M925G) Motherboard
Computers & Internet Logo
136 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
