SOURCE: Need a belt for Pronto 2 in 1 stick vacuum.
Your not gonna find a belt because the belts on these units are not designed to be replaced by the consumer and would need to go to a service station
SOURCE: Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
SOURCE: how to clean turbo brush of harmony electrolux
Wait, there are two more screws that must be removed before the top shell will come off. They are located under the wheels. Pop the wheels out by simply inserting yoru finger or a small tool into the wheel and pulling straight up. Remove those two screws and then you can proceed as mentioned above.
When reassembling the head, if the shell does not snap back onto the base, check for plastic chips or other debris in the narrow slots on the underside of the shell. Clear these slots out and the head should easily snap back together.
SOURCE: Electrolux el7020b is making a clicking noise?
You need to change the belt
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
