Question about Sony Playstation 3 (PS3) Console
PS3 WON'T PLAY DVD'S
HI,
Have PS3 set up to new tele but it won't play DVD's I am getting a 'NO SIGNAL MESSAGE'  on T.V.  games are fine.  I have heard that there are two types of HDMI cable available but am unsure of the details.  I have 1 HDMI cable which i purchased and i think that is specicfically for gaming.  And another which i think came with the PS3, but i get the same message regardless of which one i use.
    Paul C
  • 16 more comments
  • scotty958 Feb 10, 2008
    my ps3 wont play any dvds but will play games and blueray dvds fine. just not normal dvds
  • PSFreed Feb 15, 2008
    I have the same problem...non Blue Ray DVD's play fine through scart, but not hdmi
  • Anonymous Mar 05, 2008
    I put the DVD in and the screen flickers. For a brief moment I can see what looks like a 'Play' arrow in the bottom right corner, ten the sceen goes black and then 'No Signal'.
    It also seems to lock up the PS3...
  • bobfido Mar 05, 2008
    PS3 play games OK. But not play DVD'S
  • cairo1967 Apr 16, 2008
  • Anonymous Oct 13, 2008
    my games work fine but when i put in a dvd it turns black and nothing happens
  • nednil57 Nov 17, 2008
    Games play ine. Put in a DVD it loads, then screen goes blue and PS3 no longer funtions. Help.
  • jordonbrees Dec 05, 2008
    PS3 will play games but dvds and blurays wont play
  • wolfie71 Dec 08, 2008
    I have the exact same problem. LG TV
  • jsplitts2unc Dec 09, 2008
    i put in the dvd and the screen goes blank and i cant turn i on or off
  • Anonymous Dec 09, 2008
    i cannot play dvd on my playstation 3
  • darylmcphers Dec 28, 2008
    i have the same problem when i put a dvd in and it comes up no signal but works fine with scart lead. i am really annoyed with it
  • indycoltman Jan 15, 2009
    Games play fine but screen goes black when I have either DVD or Blueray DVD. Also once black will not return to main menu unless I use main power on/off located on back of console
  • ser_iousss Jan 23, 2009
    kinda the same problem, when i turn on , it turns on but no video feed i guess nothing is wrong with the cable that i can see, i have only used it for about a week total now.
  • rosiefresno2 Feb 01, 2009
    Same problem games play but screen goes black when I try to play dvds or blueray and I cant go back to the menu I have to turn console off
  • Anonymous Mar 15, 2009
    PS3 games work but blu ray, dvd and PS2 games no longer work :-(
  • Anonymous Mar 27, 2009
    i get a blue screen
  • Henry Keven Wilkinson
    Henry Keven Wilkinson Aug 13, 2014
    get code number 80029923 when insert movie dvd's
To any future people with this problem disable 1080i from supported resolutions check 720 P and 1080P only, ps3 doesnt have good 1080i support
good luck
Posted on May 13, 2009
  • Jerrycan Oct 08, 2014
    This was absolurely bang on! Thanks very much - everything is working fine, now.
1. turn the ps3 off till the red light shows. 2. hold on too the power button on your ps3 (not controller) and wait till the light turns green --> *red* 3. do that same thing again, hold it for even longer till you hear "beeping" twice (repeatedly). 4. let go, and then you should see six choices. 5. of the six choices, select number three. it should work now.
the problem is that your ps3 has a corrupt file. from either dvd, movies, pics. ect.
Posted on Jul 26, 2010
  • 2 more comments
  • Morgan Franklin
    Morgan Franklin Sep 03, 2010
    thanks a lot for that works perfectly my ps3 is whole again :)
  • perfectgti Jan 24, 2011
    thanks for the advice, it worked perfectly.
  • Colin Benefiel Jan 28, 2011
    How did you do this? I cannot seem to get it to work. I turned the power off>>held the power button until it turned red again>>held again until it beeped twice and the green and blue light remained on but there was no signal.
  • pnaylor39 Mar 09, 2011
    Fantastic!! Tried all previous suggestions to no avail but this one cured the problem.
  • 65 Answers
In your display settings on the ps3,tick all boxes 720p 1080p and 1080i and save.This should now play your dvd's provided your ps3 model is compatible.
Posted on Dec 26, 2008
I had exact same problem. I managed to solve it you go into Display Settings and change the screen resolution down to 720p it has a problem running dvd's at 1080i your dvd's should work fine now.
Posted on May 16, 2009
  • ryryz Aug 03, 2011
    i love you! thank you for saving my ps3!! such a simple fix, live well my friend. Live well.
  • Mohi Roberts May 09, 2013
    ilove you (: thank you so much. you saved my movie night
I had the same problem, mine would play games but my TV said "no signal" i got around it by reseting the connection between the TV and ps3, (make the ps3 re detect the HDMI cable).
i don't no how but it worked but,
i just kept on turning the ps3 on and off a few times and it re detected it? (it went back to the screen when you first plugged your HDTV/HDMI cable into it)
i hope this was useful
Sherwin_544
Posted on Jul 28, 2009
Ok I have the regular ps3 the big bulky one and it will not play regular dvds...what should I do?
Posted on Nov 05, 2011
Okay, if you have a proof of purchase, and if you have a warranty, you can contact Sony at the Playstation Site. If you have proof of purchase, you can send off your PS3 to Sony at no cost, as long as you are on a warranty, and have proof of purchase. They will repair it or they will send you a brand new system. Depending on the problem.
Posted on Apr 03, 2010
Ps3 wont play dvds but games work fine when i put a dvd in the screen goes blank and the ps3 wont turn off or on i have to flick the switch at the back
Posted on Mar 09, 2008
Ps3 won't play dvd once it is inserted
Is it a regular DVD? Or a burned one. It is possible, that if it was a burned copy, the format might not be supported. If it is a regular DVD, than only 2 options it could be. The easy one is, check the DVD. Are there any big scratches or smudges that would cause it not to read. If it is a new DVD, than there is a real possibility that your Blue-Ray disk drive is on it's last leg and will need to be replaced.
Apr 15, 2013 | Sony Playstation 3 (PS3) Console
My Westinghouse 32 does not play sounds for my video games for my PS3
Your signal board is bad and will need replacement. If you open up your tv and look at the signal board you can get a part number so that you can order one.
You can get get parts for this tv at www.interliquidparts.com
Nov 18, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Why won't my console play blu-ray movies
The Wii doesnt play Blue-Ray "BD" Movies, only the PS3 does, also the Wii doesn't play DVD's.
You can get the Wii to play DVD's by cracking the system by placing files on a SD Card, but your Wii will never play Blue-Ray movie because the system doesn't have the blue laser in the cd drive, sorry.
Have a nice day
Aug 20, 2011 | Nintendo Wii Console
My new homefront ps3 will play on my friends playstation but will not play on mine help
If it won't play online what you'll need to do is set a static ip in your router for your ps3 and then open ports TCP Ports: 80, 443, 5223, and 10070 - 10080
UDP Ports: 3478, 3479, 3658, and 10070
(you'll need to contact your router about that)
If it won't play AT ALL follow these steps ( http://us.playstation.com/support/answer/index.htm?a_id=1488 ) to get into safe mode and select option 3.
If NONE of your PS3 games work and NONE of your blu rays work, your blu ray drive is fried and you'll need to get it fixed. You can go to: us.playstation.com/getservice to get it fixed.
Mar 21, 2011 | THQ Homefront PlayStation 3 for...
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Ps3 message; no ethernet cable
You need to format your PS. Found under system settings on the main menu
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22,940 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
