Question about Christie Roadster X9 Multimedia Projector
Christie error message "Lamp Interlock Fault"
I changed the Christie (x9) lamp and when I turned on the projector, the LCD screen is showing the following error "Lamp Interlock Fault".
I tried many times and I checked the interlocks over and over and everything seems to be fine, but the error keeps showing and the lamp is not turning on.
  • 2,237 Answers
The switch itself may be broken. check continuity.
Posted on Jan 06, 2010
Christie LX32 Lamp
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mar 09, 2014 | Christie LX32 Lamp
Christie LHD700 projector has blue in the corners
NSHA380W *2 lamps
Original lamp ,unit price is USD320
Have a good day!
Feb 18, 2014 | Christie LHD700 OEM Projector Lamp
Lamp hours on christie LX120
VIP300W X4 lamps
Original unit lamp ,USD120
Have a good day!
Jan 31, 2014 | Christie LX120 Lamp
Christie Roadster S12K
2000W Xenon 03-900519-01P
Original lamp USD2000
Have a good day!
Jan 05, 2014 | Christie Projector Replacement Lamp -...
When I turn on my Christie DS30-projector, I get a message telling me that the lamp only has 10% left, even though I recently changed it. Is there a way to fix this? It clearly isn't at 10%.
You probably didn't reset the lamp timer after changing the lamp. All I could find in the user's manual is this: In the "utilities" sub menu, reset the lamp timer.
Jan 26, 2011 | Christie DS30 Multimedia Projector
Invalid lamp ballast id on 16k Christie This happens when the projector is powered up and the on button pushed. The lamp will strike after many tries ie dropping power and re powering once running no...
Have a good day!
wheel,
Sep 23, 2009 | Christie Office Equipment & Supplies
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
How do I change the bulb on a christie lx380 projector
open up the lamp door, unscrew the lamp, remove it, replace it, replace the door.
Dec 01, 2008 | Christie 38-VIV211-01 LCD Projector
Christie lamp explodes
the lamp VIP300w, with Hg
the lamp have the chance to explode,if the lamp used over 2200 hours
you can replace the lamp when it is about 2000 hours
Have a good day!
wheel,
Dec 10, 2007 | Christie Office Equipment & Supplies
Christie Roadster X9 Multimedia Projector Logo
547 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
