Question about Zebra 140Xi II Thermal Printer
Zebra 140xi Printer, I need to reset the password on the unit
I just got this thermal printer and I need to reset the password on it so I can change the settings to make it work on my pc? How do I do it ?
  • 31 Answers
I am not sure of the ability to change the password. I know the default is 1234. That has been the case since Zebra has first started making these printers.
Posted on May 27, 2009
  • Jim Reder
    Jim Reder May 27, 2009
    There is a Password command but maybe the easiest way to reset is go to Factory Defaults. If you know how to do the Media Sensor setup, this may be the fastest way without programming.
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
I have a Zebra 140xi and I need to do a print
If you press and hold the PAUSE key while you turn on the printer, then the test pattern used for aligning the printhead and checking for elements not working (prints a black box) will be printed.
Hope that helps !
Jun 07, 2010 | Zebra Printer 140-751-00000
140Xi II Thermal Printer: how can I put my zebra xi-140 printer in self clea...
There is no such thing as self clean mode. get a cotton swab soaked in 90% or stronger isopropyl alchol and wipe the print head. be careful not to scratch.
May 16, 2010 | Zebra 140Xi II Thermal Printer
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Need Zebra 140xi User Manual
If one is available, you will find it here - LINK
Dec 10, 2008 | Zebra 140Xi II Thermal Printer
Zebra 140Xi II Thermal Printer Logo
904 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
