Connecting speakers to amps
Hiya, we've got a pair of Kam Z Seies Eliptical Tweeter PA Speakers (Z1504 MKII) that we need to hookup to a tecnics amp, but the speakers have each got 2in/out sockets that we've got 4x speakon-jack cables for, but we're unsure of how to connect them to amp and don't wanna risk damaging any equiptment as it wasn't cheap! any idea how to do it? cheers.
Vix
  • 682 Answers
Connect right and left channel output cables from your amplifier to input for each speaker.
Posted on Apr 25, 2008
Connect JVC MX-GT88 speakers to a differant reciever
If it has a bi-amp, you can connect the speakers to it. By the amplifier, if it's a stereo with bi-amp, be sure that it has at least 400 watts and up in order for the speakers to turn out great, if a receiver like a integrated amplifier, it may have like 2-10 connections, you can connect the speakers all together if it has more than 3 connections, if below 3, you may need to take the speakers apart and make it 3 way by connecting one wire to the tweeter, another wire from the tweeter to the main or mid speaker then one more wire from the main or mid speaker to the sub.
Feb 03, 2014 | JVC MX-GT88 CD Shelf System
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
Hi, I have own a pair of peavey impulse 1012 speakers. One of them has developed a fault in that the output is terribly owful at low volume compared to the other one but an increase in the output from the...
"terribly owful " is not a descripption we can really understand. You need to describe whether the probllem is with the bass or treble speaker... lows/highs... The only suggestion we can give is to open the unit. You will need a LONG phillips screwdriver and remove all the screws in wells around the edges from the back and then gently separate the shell. Inspect for loose wiring. You don
t mention if you are using this as bi-amped or not which we need to know. This unit has the soundguard protection of the tweeter which consists of an automotive type lamp and a polyfuse. I would open the unit and see if there is a problem with the connections or possiblly a socket problem with the lamp as that would disturb the tweeter level. If you are bi-ampong this, then verify that swapping the speakers the problem is the speaker and NOT the cable or amp... Also verify the switch on the back of the speaker is properly set.
Jul 25, 2011 | Peavey Impulse 1012 2Way Molded PA...
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
May 04, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
162 people viewed this question
 Grubhead
Grubhead
