Question about Drive Geo Power Wheelchair
Where can I find a replacement motor for the Drive Geo Power Wheelchair? The left motor seems to be sliping.  Part # is s350169728
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
  • papunanda320 Sep 28, 2010
    if u have vacum chamber nwith no air then there is no problem .u can collect this from scrap hard dics for modetails contact:::== papunanda2008@gmail.com//09853886499
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
Hi there Got a grating noise on my pronto electric wheelchair. Almost like a drive belt (if they have them) is broken on one side.
No belts on the M91. Your right motor sounds like it has stripped gears. The gears cannot be replaced. The whole gearbox has to be replaced. Most stores will only replace the complete motor and gearbox assembly. Invacare may not sell just the gearbox.
May 27, 2014 | Electric Mobility Invacare Pronto M41...
Have replaced joystick and motor controller, but chair turns left when joystick is moved to right. also, motion seems eratic,what can I do????
sorry to tell u this but with a new controller and joystick u will need a tech with a programmer to redo the joystick and det up controller,so contact a dealer for help
Oct 24, 2013 | NRS Used Merit MP 3CR Power Wheelchair
Reset button keeps clicking off on drive geo
reset button could be bad . bypass with a fuse of equal rating if the fuse blows look for cause, if not replace the reset breaker
Jul 11, 2012 | Drive Geo Power Wheelchair
Intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
Oct 29, 2011 | Ctm HS-2800 Power Wheelchair
I have a power chair by Drive Medical Design & Manufacturing. The chair goes in circles. I have had it in for repair, nothing is found. I get it back and the problem starts all over.
Does your chair have the nine pin connector from the joystick to the rear of the chair? If it does have them replace the main nine pin harness in the base. this harness connects the batteries and the motors and supplies the power to your motors through the joystick. I have found these give the problem you are having yet doesn't give any errors that you might have a bad motor etc Fairly cheap fix harness should cost about $20.00 Hope this helps
May 29, 2011 | Electric Mobility Geo Wheelchair Drive...
Chair is slowing down. Batteries are fully charged.
How old are the batteries? Even fully charged older batteries can be weaker and not give you as much power to keep the speed at what you are used to. Now a dragging bake can cause you to go slower and also drag the batteries down quicker. Try driving the chair and after awhile check each motor to see if they feel overly warm or hot If one or both feel very warm or hot then I would have the brake or brakes checked If they seen ok I would get the batteries replaced
Feb 26, 2011 | Electric Mobility Invacare Pronto M41...
My Drive Cirrus Plus power wheelchair doesnt move, it flashes the first two LEDs in red and when moving the joystick it won't move or make the sound. What could be wrong? The battery is at full charge
The Drive Cirrus Plus power wheelchair is a folding frame chair with a VSI controller. The VSI controller (joystick) will indicate a fault code when it detects a problem with your power chair. It is manufactured by a company called Penny Giles Drive Technology. An LED flash code of 2 on the battery display indicates that the left motor is disconnected. There may be a brake fault also.
The left motor can be disconnected at the plug where the VSI harness plugs into the motor plug. The pins for the motor or VSI output may be pushed back in the connector or not making contact due to corrosion or dirt. Unplug this connector and inspect the pins and make sure they are making good contact and are clean. Spray contact cleaner on the contacts to clean or re-orient the pins to make better contact. The folding frame of the chair may have dislodged the connector. The wiring harness from the motor may be pinched or cut. The brake wires and pins may have become disconnected also. The brake lever may be in the disengaged freewheel position causing a fault, so put the brake lever in the correct position. Strictly speaking, this fault code is for the motor only, but always check the motor/ brake assembly since the wiring runs from the same plug.
A certified technician will have a hand held programmer to read the computer (VSI) fault log and determine the number of error codes for the various components.
Using a digital voltmeter you can check the motor at the plug. The two large wires on this 4 pin plug go to the motor; the two small wires go to the brake. On the resistance scale the motor should read between 0 and 1.6 ohms. The brake should read between 30 to 60 ohms.
There is a chance that the output of the VSI controller is bad. To test this swap the left and right motor output connectors from the VSI. If the error code now indicates right motor disconnected (flash code 4) you have a good VSI and bad left motor. Swap the leads back after you are done with this test.
Try blocking up the chair and see if the motor runs with no load on it or after spinning the drive wheel by hand. You can also inspect the motor brushes for burning and wear. If you pull the brushes, do this carefully and blow out the dust from the motor armature. This may allow the motor to work again for a short time.
You will probably need to hire a technician if, after checking for bad connections and the brake lever in the wrong position, you still have problems. I like to replace the brake/ motor/ gearbox as a complete assembly to avoid future problems. Labor for the diagnosis and reading the fault code log with a hand held programmer should be under 1 hour. A return visit to replace the motor brake gearbox is under 1 hour. Hope this helps.
Dec 25, 2010 | Drive Medical Cirrus Plus Folding Power...
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Car won't start, battery fine, just hear clicks
Even though the lights work, the battery may still be just short on power to turn the motor over thus the clicking. Try charging the battery or jumping, if you still get a clicking it would be the starter solenoid. Considering the year you may just want to replace the whole starter.
May 18, 2009 | 1995 Geo Tracker
Drive Geo Power Wheelchair Logo
141 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
