Question about Husqvarna Designer I
When I turn on my designer 1 the needle is off center to the right, not centered. Also when selecting a zig zag or other decorative stich it sews something different. Have tried recalabrating the screen no luck. Procedure I used. I selected set at the top of the screen, then pressed more twice at the bottom of screen, then touch screen adjust, then two red x's appeared I touched the top one it turned green then touched bottom one it turned green , then save. Nothing happened still the same problem
  • radcal May 11, 2010
    If you select a zigzag what does the machine stitch out??
    Problem Solver:
  • 7 Answers
These machines are computers are just that: COMPUTERS. Nothing to do but have a mechanic ltake a ook at it for possible fix. It is not communicating with the brain since settings are off. There is a manual on ebay for $5.99 that is a three-part CD and I suggest you go on-line and buy it. It will hep with parts, service and how-tos for your D-1. I have it and find it invaluable for fixing my own machines. Hope this helps.
Posted on Jun 19, 2009
Brother sewing machine model AS1430S not picking zig zag stich....on zig zag stich option it is only giving straight stich.....plz help
Try a brand new needle. If that doesn't work, then the machine may be slightly out of time. Search for sewing machine timing or take it for service.
Feb 25, 2017 | Brother Sewing Machines
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
When trying to put the needle in the far left position an error or fix it pops up
I think the needle mechanism is out of adjustment. In the center position, is the needle centered over the hole in the needle plate (check with a plate that has the single hole for straight stiching, not the slotted hole for zig-zag sewing). Take it to a professional for a tune up.
Mar 19, 2014 | Husqvarna Designer I
Needle does not align with the hole and presser foot
Sounds like a bend needle, try a new one, or else your needle plate and foot is for straight stich, put the machine in center needle postion, and reduce the zig zag to 0 or none.
Good luck and happy sewing, please rate my solution
Mar 12, 2011 | Singer Sewing Machines
Needle arm is not centered and will not center. when machine is turned on the needle arm moves completely to the left outside of the range it should be in.
You probably have your machine on a different stitch than a straight stich, such as zig zag or a button hole.
Jun 07, 2010 | PfaFF Creative 7570
The bobbin thread is bunching on the under side of the fabric,. Decorative designs are close together, not like the pattern and when I use the more intricate decorative designs, they just sit in a quarter...
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Jul 07, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
124 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
