Question about Whirlpool Washing Machines
Our whirlpool awm 360 doesnt fill up with water it just drains directly...please help
    President:
  • 1,136 Answers
Hi, First thing you want to check is your drain hose. Make sure that it is not laying directly on the floor and that it is raised up higher then the water level in the washer. Make sure that the end of the drain hose is not laying down in the water sitting in the sump pump (if applys)
Hope this helps. Any other way I can assist you, please let me know.
Thanks
Vic
Posted on May 14, 2009
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
Oct 10, 2009 | Whirlpool AWM6100 Front Load Washer
Machine does not wash just fill and drain
hI my name is joyce , you need to get a service tech to fix problem the machine has got a piece of trash in valve that controls the cut off of the water and its stuck. check the filter in the water line to make sure it is in good shape and has no trash in it, this usually happens when you are on well system with no filter on line.
Feb 06, 2009 | Whirlpool AWM5125/1 Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool washer awm 6163
ckd for drain hose to low ..top needs to be 30-38 ins from floor also needs to be loose fitting in drain pipe to prevent siphoning ..if neither is the case ckd fill hoses for obstruction in screens last ch flow meter ..remove top round object left side with small hose from fill valve 1 side other side to detergent dispenser may try tapping it while it fills if works ok replace flowmeter
Sep 09, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Jun 21, 2008 | Whirlpool Washing Machines
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
