Question about Sport & Outdoor - Others
Wiring diagram for 6 pin viking trailer. They seem to ony use the 4 traditional wires. However I picked up a generic 6 pin only to find out that the colors are different. I going to try to wire the way the original installer did for my ford. I now have a dodge with the 7 pin style adapter.
  • 182 Answers
SOURCE: wiring diagram for ford 9n tractor
You can purchase a manuel for your tractor at Tractor Supply or at tractorsupply.com for about $25-$30.
Posted on Sep 11, 2008
leetamara
  • 702 Answers
SOURCE: Installing a 7-pin trailer towing recptical on a 1991 Ford F150.
I believe you can look up the manufacturer of the trailer plug kit and find the wiring diagram there. On alot of the trailer plug kits, they have pics and diagrams in the package. The 7 pin plug (truck side) is available with the pig tail set up that plugs directly into the wiring harness for the lights. Then all you would have to worry about is the 2 wires for the electric brakes.
Posted on Nov 30, 2008
  • 1779 Answers
SOURCE: Looking for a wiring diagram for a 2006 Ford Expedition
7way- black is 12volt (power), brown, running lights, yellow is left turn signal and stop light, green is right turn signal and stop light, white is ground, blue is brakes, and orange is aux power (can be back up lights, if trailer equipped w/ them). 6way is the same, minus orange wire. I have run into some variations to the above color codes (brown, yellow and green only-sometimes these 3 are different than stated, but only mixed as that group, as to what they control- example would be green is running lights, brown and yellow are turn signal and stop lights, the others should be as stated), if you have any trouble with things not working properly, it may be due to these variations, although the above are pretty standard. If you have an ohm meter you can check as you go (check for power at black wire- should be constant 12v, turn on turn signal and check for power-it will fluctuate from approx. 12 volts to 0 volts as the signal power pulses in the wire) hit the brakes, blue wire should show power, etc. Let me know if you need more help as you go.
Posted on Apr 11, 2009
snotaprob
SOURCE: Recently purchased a caravan with a thetford c-200
you may have this already but try
http://www.thetford-europe.com/web/show/id=51498/langid=42
Posted on Apr 26, 2009
micromaster
  • 3614 Answers
SOURCE: wiring diagram.
hi there,
try to find the wiring diagram HERE
just let me know for further assitance.
thank you
Posted on Apr 28, 2009
Electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
I have a 2011 f250 super duty when I plug my goose neck in I get an error message-I have tried switching wiring around but cannot seem to find the right combo-can you tell me which colors repesent which...
Here is a link to a web site that will give you the wiring diagrams based on industry standards. Your truck has 7 wires because If I remember right the 7th is for back up lights on the trailer. I have a '94 F350 with a 7 pin connector and on ly 6 wires used as my trailer doeswn't have back-up lights.
http://www.etrailer.com/faq-wiring.aspx
Aug 11, 2011 | Ford F-250 Cars & Trucks
Instructions for wiring a moving trailer connector
Trailer Wiring Diagrams 4 Way Systems
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white).
4%20way%20wiring.jpg 4way_vehicle.jpg 4 way tow vehicle side.
4way_trailer.jpg 4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5way_vehicle.jpg 5 way tow vehicle side.
5way_trailer.jpg 5 way trailer side.
6 Way System, Rectangle Plug 3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6way_rectangle_1.jpg 6 way tow vehicle side.
6way_rectangle_2.jpg 6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6way_vehicle.jpg 6 way tow vehicle side.
6way_trailer.jpg 6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7way_vehicle.jpg 7 way RV flat blade tow vehicle side.
7way_trailer.jpg 7 way RV flat blade trailer side.
Jan 01, 2011 | 2001 Pontiac Montana
2008 GMC C5500 factory wired for trailer harness (7 pin). I just purchased brake controller and am trying to find where the controller harness plugs into the truck harness. Looking under the dash. Plug...
You are probably going to find four wires together that do not have a plug on them. There should also be a tag taped on the wires showing that it is for the trailer. You will have to put a plug or some kind of connection on those wires.
Mar 13, 2010 | 2008 GMC Sierra 3500HD 2WD
Tail light wiring connectors and wiring diagram
A test light checking each connector would be faster and easier to do. Maybe somebody may have a illustration for you but by far a simple test light is all you need with a helper turning on the different lights as you check them out and writing all your findings down
Jan 22, 2010 | 1997 Ford F350 Crew Cab
2005 2500HD battery charge for trailer
Here is a page online that has wiring for the 7 pin coupler. http://rvbasics.com/techtips/rv-travel-trailer-plug-wiring.html Notice that the battery charge for the trailer is on pin 4 black... Hope this helps you with your hookups. K
Jun 06, 2009 | 2005 Chevrolet Silverado
Wiring diagram
If you are going from a 4 pin on your trailer to the 7 pin on the truck. You need to go to parts store or a department store (ex Wal Mart) and look in trailer section and find the adapter. Thats what I did. Also Remember if your lights don't work on trailer, check the plug to make sure its tight or check the fuse under your drivers side rear seat for that fuse box.
Apr 15, 2009 | 2006 Chevrolet Trailblazer
I need a wiring diagram for a 7 pin trailer board plug
Here's one
08-33-93f1.gif CAV CIRCUIT FUNCTION 1 Z13 12BK GROUND 2 B40 12LB TRAILER ELECTRIC BRAKE OUTPUT 3 L76 12BK/OR TAIL LIGHT (Trailer Tow Relay in PDC) 4 A6 12RD/TN* FUSED B(+) (40A, Always Hot, F8 in PDC) 5 L63 16DG/RD LEFT REAR TURN SIGNAL TRAILER TOW 6 L62 16BR/PK RIGHT REAR TURN SIGNAL CONNECTOR 7 L1 16VT/BK BACK-UP LAMP FIGURE 1: 7-Terminal Trailer Tow Connector
Mar 12, 2009 | 1993 Land Rover Defender
Trailer Connections
I took the vehicle to Bosch, an electrical expert in Germany.
Jun 28, 2008 | 1997 Ford F150 Regular Cab
Sport & Outdoor - Others Logo
1,418 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
