Question about Kenmore 4292x Front Load Washer
Code F dL on Kenmore Elite HE 3t
My washer stopped working with the above code.  I have tried the solutions posted previously (unsucessfully), which would probably work fine, but for the small detail of not being able to remove the screws.  Is there some trick?  I have tried both allen wrenches and screwdrivers with no success.  Please help if possible.  The washer is full of water and there are now sopping wet clothes in my sink.
Thanks!
  • danescott Jun 10, 2008
    I having the same problem, although I'm also getting some faint clicking sounds. HELP!
  • ken7491 Oct 20, 2008
    I dont know where to start -- where are the screws that need to be removed -- and what debris am I looking for???
  • 246 Answers
The screws are a #20 torx bit. Once you take those out, remove the panel. Behind it is a white plastic pump. I usually remove the torx screw in it too so it can come out further and I can get a bucket under it. As you unscrew the front of it counter clock wise, drain out the water SLOWLY. Then clean debris from the trap.
Posted on Jun 15, 2008
KENMORE ELITE OASIS- comes up with a code: DL ( REPEATEDLY - CHECKED THE LOAD- BECAUSE IT STOPS- WON'T RESTART.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Where can I find a door latch for the Kenmore HE 3t
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Jul 19, 2010 | Kenmore HE2 Plus Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he 3t gets a code t
Hi
Thanks for using FixYa and Thank You for accepting the previous solution. However, please describe the complete error that you can view on your Kenmore elite HE3t so that I can assist you.
Thanks Rylee
Apr 11, 2010 | Washing Machines
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
Received an error code dl f on my Kenmore Elite 45986. Replaced the locking mechanism and I am still receving the same error and results. It just clicks and gives this error code. Thanks "dl F" error code...
The "Fdl" error code indicates a problem with the door latch assembly. The clicking sound you hear is the door latch attempting to latch. If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. It's strongly recommended that you leave the tech sheet inside the washer, so you don't lose it.
Repairclinic.com carries the door latch for about $50 and is listed as item number 1094190.
Searspartsdirect carries it for slightly less for about $43 and lists it under the "Door and Latch Parts" as item number 7 (part #8181700).
If you go to my profile and click on "Tips and Tricks" I have a posting there on how to change the door latch on a front loader. It's a very simple repair that any Do-It-Yourselfer can accomplish.
If you can't find the instructions you need, or need further assistance, please post back and let me know. I hope this helps you.
May 11, 2009 | Kenmore Washing Machines
Kenmore elite washer f11 f14 and dl codes
Replace the CCU it is your only choice. They do not make bandaids for washing machines. If you dont fix it you will just have a non working machine soon
Mar 31, 2009 | Kenmore Washing Machines
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
