Question about Palm AT&T C/PHONE PALM CENTRO S64801
Finally go my Palm Centro to turn on...all my data is gone
I had trouble getting my Palm Centro to turn on. Finally turned con but now all my settings and data are gone.
    Problem Solver:
  • 9 Answers
Need to resync your phone to your computer. the settings and info you had before will be saved there. if you never hotsynced your phone to your computer before this, you're outta luck and you gotta do it the old fashioned way, retype everything back in.
Posted on Jul 02, 2009
I have an black one and everytime I turn it on its asking for an password and I don't know it
Hello guccimane04,
A hard reset will unlock the Palm Centro But it will ERASE ALL of your data. If you choose to do a hard reset, the following procedure will work:
• Remove the battery cover on the back of the Palm Centro
• Remove the battery for a few minutes
• Press the power button when Reinserting the battery
• Release the power button after the Palm logo displays on the screen
* The hard reset erases all your data ! (Run a hotsync to retore the data) *
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 20, 2010 | AT&T Palm Centro Cell Phone - White
Pal m centro touchscreen disables after receiving
Hello 150pilot,
To manage an active call when the touchscreen is disabled, use the hardware buttons on your Centro (on left side of the Centro).
- OR -
The keyguard feature might be accidentally enabled. To turn off Keyguard, do the following:
• When the screen is off, press the red power button to wake up the screen.
• Press the center (Palm) button to turn off Keyguard.
You can change how quickly Keyguard turns on, or you can disable this feature altogether. To change the Keyguard settings, do the following:
• Press the Home button
• Select System from the category drop-list at the top of the screen
• Select Prefs
• Select Keyguard.
• Select the Auto-Keyguard pick list, and then do one of the following:
-Select how quickly you want Keyguard to turn on: When power is turned off, 5 seconds after power off, or 30 seconds after power off.
-Select Disable to completely disable the Keyguard feature until you turn it on again by pressing Option + Power/End when the screen is on.
4 Select Done.
More information about the keyguard feature canbe found in the Palm Centro User's Guide:
http://www.palm.com/us/support/handbooks/centro/centrosprint_ug.pdf
Have a great day,
martyshaw152
Jan 16, 2010 | Sprint Palm Centro Smartphone
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
Tried to lock my palm centro never gota question to set password just lock the device now cant get in my phone.
You may want to try a hard reset. Keep in mind you will lose all data in your phone. These steps restore the phone to factory settings
1. Remove the battery from the rear of the unit.
2. Hold down the power button while reinserting the battery.
3. When the Palm2_bing.gif logo appears, release the power button.
4. Press the Up button to complete the hard reset and erase all data on the Centro.
Dec 14, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Centro - continous Syncing problem, now phone is dead
This happened to my palm centro and i fixed it myself. :) Maybe it will work for you. What i did was take out the battery and so the phone is completely off.. then take a tooth brush with rubbing alchohol on it and scrubbed the bottom part of it that the hotsync cord goes into.. I thought this may just mess up my phone more but i plugged it back into the power cord, turned it on and it worked just fine!! Seriously, try this out. It brought me so much relief!! And chances are you either got some **** stuck up inside there, or you got the botton part wet. Hope i helped!!
Aug 24, 2009 | Palm Treo 500 Centro
I cant use any other sim card on palm centro phone which is unlocked one. i can use airtel india with internet but others are not accepting internet connection
Every operator has its parametre for recieving data or GPRS and 3G (UMTS).Your phone is configured for airtel but if you want to use others their parameters must be entered separately and set as defaul correct one when changing SIM. To find parameters wisit other operators pages, there may be special numbers where you can call and recieve data messages containing parameters and simply save or find instructions how to manually enter them. Also you must activate WAP/GPRS function in every opearator and it winn need aditional charge.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Hi, my palm centro has no sound. i.e, no speakerphone, no dial tone, no audio on videos but the alarm works that's it.
Hello rossgreni340,
First, make sure the ringer switch is set to 'ON'. It's the little button on top of the Centro. It's turned on when it's pushed to the left. If that doesn't help then check the Sounds settings. The Palm Centro sounds settings can be accessed and changed from the 'System' screen like this:
•Press the 'Home' button on the Centro.
•Tap the 'System' category (top of sscreen).
•Tap 'Sounds' to change the sound settings as you desire.
I hope this helps to resolve the sound problem.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Jul 29, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Why does the centro turn on and off by itself
http://forums.palm.com/t5/Support-Downloads/Palm-Centro-ROM-Update-for-Freezing-Issue/td-p/165101
Jun 27, 2009 | Sprint Palm Centro Smartphone
How to do a master reset on palm centro
The steps for a hard reset (warning - you'll lose all the data - back to factory settings) are described at this link: Link to Palm solution.
Jan 16, 2009 | Palm Treo 500 Centro
MY PALM CENTRO WONT STAY ON. IT TURNS OFF RIGHT AFTER I TURN IT ON, AND MY BATTERY IS FULLY CHARGED
Try look at the setting by pressing the House (right key)
Choose Prefs, select Power --> check time of Auto-off Receive --> set to maximum time
Try and see if this works
Nov 20, 2008 | Palm Treo 500 Centro
Palm AT&T C/PHONE PALM CENTRO S64801 Logo
102 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
