Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT-53WX42 The convergence went out and when I tried to adjust it in the menu it would not adjust enough. The convergence seems to be off basically just the red after reading this forum it must be the convergence IC's that are bad. I need to know what parts I need? How much it would cost to fix it? And if I may be able to fix it myself? Thanks a lot I appreciate it.
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com . They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 14, 2009
  • 934 Answers
Aok1945,
This set uses two Sanyo Stk392-110 amps and six 2.2 ohm 1w resistors in the convergence. Parts are under $50.00 but the last part of your question is the tricky one, what skill levels do you have? On a scale of 1 to 10 and anything over a 5 being a skilled tech this repair would score an 8 because of the removal of the signal board to desolder the amps and applied heat stress on the 40 pin amps putting them in place.
If you need to locate a tech try http://www.tvrepairpros.com/ and ask a few for their estimate on how much to replace the above.
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
3 Suggested Answers
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
Posted on Sep 08, 2007
premtech
  • 934 Answers
SOURCE: PT-53WX42
Need to replace the convergence amps and any 2.2 ohm resistors in the return. That unit takes two STK392-110 Sanyo amps - but for greater reliability use STK392-150's and get them, from some place like ACME to be insured their not chineese knock-offs..
Bill
Posted on Apr 09, 2008
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Pt-53wx47f
you will need to do the convergenace adjustment for each different format then save each setting for each adjustment.
Aug 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-53WX42
Bill
Apr 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence
You need new convergence amps, and if you dont know what you are doing in the tech menu you could ruing the set. Call a Repairman Delicate soldering is required.
Jul 31, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Bent Image
Left rear on processor board
Oct 13, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
530 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
