Question about Philips 60PP9401 60" Rear Projection Television
Convergence i have a philips 60pp9401 set with a convergence problem i have read the instructions and my remote does not have the intelisense button model #2017/01b i would really appreciate any advice. there is no focus and there are lines running through the top mostly green.
  • 934 Answers
This set is made by Hitachi and uses two STK392-110, Sanyo amps to control convergence. You have likely one amps that is shorted causing the problem, but it's HIGHLY recommended that you replace both amps. Also it uses 1.8 ohm 1w resistors, out in front of the amps, for the yoke return circuit and one or more of them may need to be replaced if they are beyond tolerance.
For this job you need a soldering station, VU meter with a ohms test, desoldering braid and a skill level of 8 on a scale of 1 to 10. Anything 5 or above would be a category of someone schooled in electronics.
If you need to find a tech in your area I suggest http://www.tvrepairpros.com/
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Posted on May 14, 2009
How to adjust the convergence setting in a phillips model 60pp9401 tv
Use your remote and goto the convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jun 14, 2011 | Philips 46PP9302 46" Rear Projection...
I own a 60PP9401 60 in. Rear projection tv. My red convergance was way out of line. I placed tv in the shop a while back,cost me $300 to get it fixed! Got set home, red still out of line,but not as bad. My...
This set has an advanced menu for adjusting the convergence and what may have happened is the shop adjusted it (It is done with an original Philips remote) and then not SAVED THE ADJUSTMENTS INTO THE SET'S MEMORY.
I can if you have the remote get into the menu and adjust and SAVE the adjustments. If the set is HD the convergence will have to be adjusted two times, once in regular and once in HD.
Let me know if you have questions.
SD TECH
Jan 10, 2011 | Philips 60PP9401 60" Rear Projection...
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
I have a phillips 60 in rear projection tv model #60PP9401. and it is exhibiting the appearance of double vision, can this be fixed economically
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
I have a 60pp9401 without a remote and am unable to function the intelisense to attempt to realign colors that are way out of alignment
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Dec 14, 2010 | Philips 60PP9401 60" Rear Projection...
Picture seems to be losing its sharpness and colors bleed
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 22, 2009 | Philips 60PP9401 60" Rear Projection...
Lost remote / convergance problem
u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
Convergence problem on Philips 60PP9401
2.2 ohm 1 watt...................................T.
Nov 10, 2007 | Philips 55PP9401 55" Rear Projection...
How to access convergence board on 60" Philips?
First thig you are going to need is the service manual, as this will have the disassembly instructions and the alighnment you will need to adjust after the board is repaired or replaced. there will be two IC's that should both be replaced at the same time. they will start with STK and will be soldered onto the printed circuit board and mounted up against a large metal heatsink.. These ICs can be replaced, but if you have no soldering skills or no experience working on Printed circuit boards, the entire board is available at http://www.ptscorp.com/tech_support.html. Good Luck
Mar 28, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 60PP9401 60" Rear Projection Television Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
