Question about Rowenta KETTLE Electric Kettle
Pressing iron My pressing iron not heating but still shows the on light
  • 24 Answers
Re: Pressing iron
What is the model? If it a electronic type with auto cut off then these could be the electronic device is faulty.
Posted on Feb 29, 2008
0 characters
3 Points
Help! Iron is not hot. Thermostat light does not go on when temperature control is rotated. iron glows and can hear thermostat click when move through temperature range.
First, check and see if the iron was made in China.
If so, you can very likely not get any parts for it.
Second, if you could actually take it all apart, you would likely find the problem in the "points" inside the on/off/temperature control switch. Over time, and subject to the quality of the part in the first place, these parts fail, and the iron must be replaced.
I have taken several of these apart, and use the experience for education, since I have yet to ever get one "fixed".
God bless your efforts.
Jan 01, 2016 | Russell Hobbs 17877 Easyfill Iron
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ... > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Electric Kettles
Press start, lights up but shuts down after few minutes does not boil Why?
If it's consistently heating but shutting off early before boiling it likely has a faulty thermostatic (bimetal) switch. If it's random there could be other reasons.
Jul 16, 2014 | Cuisinart Electric Kettles
Possibly blocked with scale, try put 50%vinegar 50% water inside and leave for 1-2hrs
Jul 07, 2014 | Russell Hobbs 15207 White and Purple...
Dead cuisinart electric tea kettle
Your tea kettle has a thermal fuse inside that more that likely got over heated, it happens all the time with irons, coffee makers, most small appliances that are electric. you have to take the bottom off to find it and replace it. does it have an indicator lamp?
Sep 18, 2012 | Cuisinart Tea Kettle High Quality...
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
The kettle lights up but won't heat up, just bought it, the on switch shows red, but it is not working...what to do??
Too funny, but I solved the problem by returning the Kettle, all
the correct lights came on but it would not purchased a
different one.
Apr 12, 2010 | Bravetti EK119H Electric Kettle
Kettle doesn't heat up and no light comes on when press the On button
Check the obvious, 13amp fuse, if intact connect a multimeter switched to ohms across the live and nuetral pins of the plug (not plugged into mains) the reading should be between 0.05 ohms and 1.5 ohms if higher the element has burnned out or the over temperature sensor has activated. to determine which you will need to open up the bottom of the kettle and expose the wiring. using the above multimeter with the same settings locate the heating element this will have two terminals protruding from the water compartment thes will have eithe screw or spade connections, connect the multimeter across these two terminals and check for the readings above if correct the problem is the over temperature sensor if not then the problem is the heating element. the over temperature sensor will be a circular disk with two terminals clamped to the underside of the water compartment.
Aug 27, 2009 | Bosch TWK-9110UC F.A. Porsche Water Kettle...
Electric Kettles Logo
Top Rowenta Electric Kettles Experts
Are you a Rowenta Electric Kettle Expert? Answer questions, earn points and help others
