Question about iRiver H10 MP3 Player
IRiver H10 Wont Turn on
Well My little cousins and family members came to visit us today.Well this morning i was hearing some music on it, then let my cuzins use it then like at the end my freind was hearing music... but after and hour i want to use it and it wont turn on no more. It was fully charged.Tho when i plug it in trough computer, the screen turns white and nuthing else happends.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
How to replace battery for iRiver H10 MP3 Player
push the tab in on back of unit and slide battery off install new battery by sliding it back on and you will hear it click back into place
Jan 02, 2008 | iRiver H10 MP3 Player
Iriver H10 V's Vista
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Delete music H10 iriver
Sorry, but the built-in firmware only allows you to do that by plugging it into your computer as a removable device. Pull the battery of the player (or press the reset button), plug it into your computer, and press and hold the OK button as you turn it on. This will cause the computer to recognize it as an external drive, and you can therefore delete music from it by accessing it through My Computer.
Dec 21, 2007 | iRiver H10 MP3 Player
Sync itunes to Iriver h10
well itunes only works with the ipod for syncing music, windows media player 10 and 11 is where you would sync you music i would add your music to the media player library and go from there
Jun 29, 2007 | iRiver H10 MP3 Player
I can't hear any music
Replace - cannot be repaired
Dec 14, 2006 | iRiver H10 MP3 Player
System files missing
Reacquire firmware from IRiver website
Oct 09, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
98 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
