Question about Mitsubishi VS-45603 45" Rear Projection Television
Mitsubishi model no. vs45603
It is a 1999. and if you remove the antenna off back the frying sound is there sounds like a sound transformer needs adjusting.
    Sergeant:
    Champion:
  • 255 Answers
Ok, then you'll need to call a tech for that.
Posted on May 14, 2009
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
Getting the tuner to work
maybe you have an antenna problem, check for loose antenna wire at the back of the receiver, if thers a frying sound you need to connect the antenna
Jan 20, 2014 | Kenwood Audio Players & Recorders
Radio won't work Cd works Dodge Ram
it could possibly be that the antenna in back of the radio came unplugged and if that is plugged in check the connection at the antenna if that's fine the radio side of the sound system is fried
Dec 03, 2013 | Cars & Trucks
Mitsubishi wd-y577 blinking green timer light doesnt stop blinking ever. Replaced all caps on pcb and dmb. Unplugged dvi board and still flashing. When power is pressed after aural response that bulb is...
It's possible that you have a fried diode on the secondary side of one of the power supply transformers. Look for one that reads like a wire on an ohmmeter. Note that some diodes come in TO-220 packages so they look like plastic power transistors. (Don't be fooled by capacitor bleeder resistors - if present, these are in the tens to hundreds of ohms, so this is what you will read instead of the diode if the diode is good.) The whistling noise could be a switching power supply transformer with an overload as a result of the diode, although the primary-side power controller circuit should shut down immediately before letting that happen. It could also be coming from the speakers - that would be a hint to check the power supplies feeding the audio circuits.
If after that you are sure all of the internal cables are connected, especially to the light engine, it's time to start checking voltages and waveforms, beginning with the power supply. You apparently have power to the bulb and color wheel, and probably to some of the control circuits, but that of course is not all of the set. Most sets have some fine print on the power supply circuit board telling you what the voltage outputs are supposed to be.
Oct 13, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
Sound is distorted on this Mitsubishi Model No. vs-45603
how old is your unit?sometimes distortion is caused by interference,like motor or automobiles but that is minimal.connection of the antenna , cable and other connectors can also be the caused.if all these are not the cause, call a tech.the audio circuit is faulty.
May 14, 2009 | Mitsubishi VS-45603 45" Rear Projection...
When turn on no picture and there is a high pitch buzz or frying. Then after a minute or two it will shut off by itself. Before thid happened the picture would come on slowly with a frying sound and then...
my first instinct in this is flyback transformer. or if it is three tube projector could be a high voltage splitter lines in picture sound like what is called retrace lines ... this is another indication of a possible bad flyback. high pitch sound is another sypmpton of a high voltage flyback transformer problem. WARNING televisions generate potental lethal charge. the device called flyback is used to generate several THOSAND volts. so be carefull if you take the back of any television. along with the flyback the horizontal output transistor possible could have failed. What type of tv is it? model
Oct 01, 2008 | Televison & Video
1992 Diamante troubles - electrical
start by putting the old one back to see if everything works.
May 28, 2008 | 1992 Mitsubishi Diamante
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
Sound gone on tv big screen guideplusgemstar
this you forget the MUTE buttom on the remove control?
Dec 01, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
