Truck sat for abot 4 yrs runs great have to add a halfe quqrt of oil per month tail ie is moist
Engines that sit for long periods of time suffer from hardening of the seals and rust. There is a very good possibility that the valve stem seal will be hard and cracked allowing oil to be drawn down into the chamber during idling and the rings would have been rusty or running in rusty bores so there will be pitting in the bores. If adding oil is not a problem to you then the oil consumption will only get you into trouble with the pollution police.
Testimonial: "that was my way of thinking thank you"
SOURCE: started when i added a
Hello white smoke is usually engine antifreeze,Blue smoke oil burning,Black smoke car running to rich on gas,gas is not burning properly.
SOURCE: 2001 CHEVROLET 6.6L I PULL OIL DIPSTICK NOTICE
sounds like you have a cracked header or engine block. would take it to a mechanic quick
SOURCE: 1987 Chevy R10 project truck won't start
check the float on the carb is stuck shut not letting fuel in
SOURCE: My 2001 Silverado 6 cyl has started making a
coolant leak may be intake commend on Chevy truck,,mite want to try locus oil treatment,,
SOURCE: i have a 1998 chevy 2500 4x4 6.5 diesel pu.truck
the head gaskets are blown you can believe that anytime on any engine gas or deisel that you get oil in the radiator and there water/ antifreeze in the oil pan the gaskets and or cylinder heads are bad
