Question about Nintendo Wii Console
Wii Remote Problem
I own a Wii and one of my controllers seems to be having a problem. The motion sensing works just fine - I can point and click however much I want to, but when playing any game that requires the remote to be swung (i.e. Mario Strikers (for hitting other players), Wii Sports, etc), it doesn't work. It doesn't register that I pull the remote back when I want to wind up for bowling, it doesn't register that I'm swinging/flicking it for baseball and tennis.
I've tried new batteries, I've tried re-syncing it, I've tried reconnecting it, but nothing fixes the problem. Can anyone suggest a fix? Thanks very much!
  • 28 more comments
  • smidd1y Nov 17, 2007
    I have same problem wth my wii controll works fine untill you want to swing or let go it does not work! unhappy kids help me please
  • Anonymous Nov 17, 2007
    no arrow to select discs
    arrow not on screen to select discs
    nintendo wii wireless no picking up arrow to select discs
  • bima Nov 19, 2007
    my wii remote is not working, the batteroes r not working too. I changed the batters to new ones and it didn't work still. can u please tell me how to fix it oh and it says to connect a wii romte and I dont know how?
  • Anonymous Dec 02, 2007
  • stuartmc Dec 15, 2007
    I have the same problem - My remote seems to work fine, until the actual game starts and I have to move the characters, then it is just like it doesn't exist. Help?!
  • Anonymous Dec 18, 2007
  • ghghghghg Dec 18, 2007
  • Anonymous Dec 25, 2007
    same problem
  • dagwoods Dec 25, 2007
    I have same problem. Tried "spanking" it and nothing changed. It doesn't know I am swinging it, althought it knows I have released the "B" button. Any other suggestions?
  • jman99 Dec 25, 2007
    Wonderful...Christmas Day and the kids are thrilled to have it work again. Spanking the remote..."Spare the rod..." Thanks!
  • Anonymous Dec 26, 2007
    Same old problem, works fine selecting wii sports- tennis, etc, tho when the game starts, it doesnt work. tried new batteries, syncing, smacking.................................
  • danask Dec 26, 2007
    When trying to bowl the remote will not allow you to bowl or play tennis. Checked the remote and sensor/sensitivity....seems to be fine. Help!
  • Anonymous Dec 27, 2007
    i was playing it at first and then i turned it off and when i tried to turn it back on it wouldnt work like the leds just blink but wont connect
  • majorang Dec 29, 2007
    I'm having the exact same problem and we just started using it 3 days ago.
  • Anonymous Jan 03, 2008
    I am having the exact same problem.
  • Caleb123 Jan 03, 2008
    I have the same problem. Mianly with Wii sports, the remote contrl is not in sinc with the game either it is too early, too late or doesn't work at all. I have tried new batteries, I have cleaned the disc, What else can I do?
  • Riverstar Jan 25, 2008
    yeah i have the same problem. sorta. my wimote wont work at all! not at the menu or anywhere! it says im not connected...but ive tryed syncing it, that wont work. any help? im starting to really want to play right now. im bored.
  • Anonymous Feb 03, 2008
    remote control does not work, light does not blink, con not sync. I have tried changing batteries but continue with the same problem
  • Anonymous Feb 29, 2008
    its a bad connection on your battery plate. Open your wii mote and look at the battery plate connected to the chip board one side shoud be stick up causing a bad connection. Im trying gorilla glue, but if you have a soldering gun that would probably work better.
  • Wii nuts Apr 27, 2008
    i have the same problem i can go on my WII SPORTS and everthing is ok i go on baseball go to swing and ..... nothing happens !!!!
  • Anonymous Apr 28, 2008
    I have the same problem. Will Nintendo fix this?
  • jeremyd2010 Jul 02, 2008
    I can't turn on the wii with the remote & the light blinks but the remote won't work right & i press 1 & 2 at the same time & I've done it on both remote & it still won't work
  • lil alool Jul 06, 2008
    hi i have been experiencing the same problem the wii remote turns on and then when i want to swing to play wii sports it does not pick up and if any one can help it would be much appreciated
  • Anonymous Jul 06, 2008
    i have tried new batteries .it wont let my control sync.
  • Anonymous Jul 24, 2008
    Hi i am getting pissed cause none of my wii remotes are now synced I have 1 remote from here and 2 from japan I haved trying whats said on here to resyc them and nothing happens.I am considering taking out the battery and replacing it and then hopeing it will sync 1 on them atleast I have a Pal wii by the way i tryed all different batteries and nothing apart from trying the panasonic ones they come with and I also dont think I have tried any other alkaline ones I am not certain.I dont know why nintendo have done this the wii motes should have been made easier to configurate and their not its a major pain.
  • Anonymous Aug 17, 2008
    wii remote doesn't work. the motion sensor doesn't work
  • mmmmm229 May 08, 2009
    my 2nd wii remote blinks then stops
  • kenton_carry May 11, 2010
    Wii Remote problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide,
    that explains step by step to fix the problem without any technical
    knowledge. I hope this guide will solve your problem. It also gives
    information on fixing many Wii Related Problems, so its a kind of Wii
    Problems Reference Fix Guide.
Try syncing the remote (under the cover on the back of the wii remote where the battery's are there is a circular red button press it then on the front of the wii where you can put your SD card there is a rectangular button press it if that does not work then try doing it the other way around if that does not work keep trying if that does not work i dont know what will
Posted on Jul 31, 2012
I had the exact same problem. My remote worked on the menu but did not work to swing in baseball or to bowl. I gave it a hard slap on the backside and it seems to be working fine. It was fun also.
Posted on Dec 15, 2007
Hi there
Had the same problem the motion sensor worked fine choosing the game, number of palyers etc but would not work for Wii sports no hitting in baseball and a lopsided boxer!! Found another web page that suggested turning the Wimote over and spanking it.  Thought what the heck and tried it - solved the problem working fine and have a very happy child again!!
Posted on Oct 20, 2007
  • 25 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
153
Posted on Mar 22, 2009
I was having the same problem. i was so furious i was about to to throw this thing away. my first remote stopped working about a month ago. everything worked except it would not swing in the tennis game. today same thing happened w/ my second remote. so you can say i was pretty pissed. my batteries had full power. i went ahead and reset the whole system and scrubbed the battery connectors w/ a knife to get a better connection. working perfect now.
Posted on May 29, 2008
Its all to do with the motion sensor bar..i found if its located on top of your tv it works better. ocassionally if the remote is dropped the alinement can also be tempermental.
Posted on Oct 19, 2007
  • lego5773
    lego5773 Jul 31, 2012
    in the settings of the wii you can set the position of the sensor bar
Intec wii remote will not sync to wii
there is a red button on the original Wii press that button do that while pressing the power button on the Wii controller
Dec 25, 2012 | Intec G5701 Black/white Wave Plus Remote...
While playing any game on Wii Sport Resort: my 2 controllers seem to be synced ok, I re-synced several times. Both controllers work fine at menu levels. But after choosing a game, number 2 controller...
I had this problem and it was down to be, me plugging the motion plus into the wrong controller.
I have one control with intergrated motion plus and the other uses a plug on motion plus. I accidently plugged the plug on one into the already intergrated control leaving the one control with nothing. Hence that control could not be recognised.
Hope this helps
Dec 06, 2010 | Nintendo Wii Remote Controller
I have tried syncing the wii remote and it still wont work...little blue lights just flash and then nothing. What do i do?
Did you hold both buttons for a few seconds?Also when you sync the remote,you need to point it at the motion sensor bar.Hope that helps.Good luck and game on!
Jul 08, 2010 | Nintendo Wii Remote Controller
Motion Controls on remote are not working
There is a very small circuit element inside the wiimote called an "accelerometer" (it heats a small vacuumed area to sense yaw, pitch and roll with thermometers).
It sounds to me like you have a malfunctioning accelerometer, which could be replaced in theory-- that sounds like an exciting challenge to someone whose electrically inclined, such as myself. However, doing so would require finding the correct replacement online and substantial soldering skills to replace it.
Mar 05, 2010 | Nintendo Wii Console
Wii remote not sensing
ahh. First im going to go threw the obvious:
1) Make sure that you see that little blue light on the WiiMote.
2) If you don't, try to sync it to your Wii.Press the red button under the little door on the front of you wii, at the same time press the button on the back of the wiimote.
3) make sure there are good battery's in it.
If that doesn't work go to this link: http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Feb 16, 2010 | Nintendo Wii Remote Controller
Controller & two player mode problem whit Wii Sport Resort
Hope this helps
Jan 13, 2010 | Nintendo Wii Remote Controller
Wii remote not sensing motion
The senser might not be working this happened to me and we googled and we just ended up buying new remotes or the batterys. the light will be on if they are dead. well ours did.
Jul 21, 2009 | Nintendo Wii Console
Wii mario kart, second wheel won't turn
I tried resyncing from the main screen, but one of the wiimotes still didn't work. I read to smack the wiimote facedown in your hand a couple of times, and that worked!!!
Apparently the motion sensor can get stuck inside, although it doesn't totally make sense, because previously when the wiimote didn't steer, it still moved on the screen to choose character, car, etc.
Dec 25, 2008 | Nintendo Mario Kart (Wii) for Wii
Wii freezing up
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to Nintendo.com, click Support, and go to the Wii Troubleshooting section for more options.
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Apr 01, 2008 | Nintendo Wii Console
Problems With The Wii Remote Controller
hi yeah i had the same problem with mine i phoned nintendo and they told me to turn the remote on its side and tap it three times on a hard surface this resets the motion sensor on the remote and yes it works,im am now a happy bowler. let me know if it works chez111@hotmail.com i also have number of nintendo if needed
Jan 14, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
2,273 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
