Cars & Trucks Logo
Posted on May 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buzzing Sound Coming From right side of dash
When my car is driving or idling, there is a loud buzzing sound coming from the right side of my dash. then when i turn my blinker on for either direction it buzzes to the clicks of the blinker. what is my problem? haha
Jerry Koski
Level 3:
  • Oldsmobile Master 443 Answers
  • Posted on May 14, 2009
Jerry Koski
Oldsmobile Master
Level 3:
Answers
443
Questions
Helped
222291
Points
1231
You need a new flasher.. get under there or read the book and find where it is and replace it..
Buzzing sound coming from under the back end
Under the left side of your back seat is a fuse / relay box . When you first turn the key on the fuel pump relay turns on for a few seconds to prime the fuel system . That relay is in that fuse / relay box ,that is what your hearing . Does the vehicle start an run good , no problems other then the buzzing sound .The vehicle battery is also under the rear seat on the right side . How To Locate and disconnect Battery Buick Lesabre Pontiac Bonneville 00...
Loud buzzing noise seemingly coming from gauge cluster area. Only happens when car is moving under load, or not under load. Does not happen when vehicle is idling.
Could be seat belt Buzzer / Door / Tailgate not closed securely warning Buzzer Stuck ON since car in park these buzzers do not activate but you said under movement sound occurs .. Mechanically I would Check Altenator for Proper Charge output - Then Ground wires for Battery / Corrosion needs cleaning ?? - Plus Dash Cluster must be Grounded Tightly .
2answers
I have a 2000 Honda Accord and as I accelerate over 45 mph the care starts making a progressively louder humming/buzzing sound. When I turn slightly to the right the noise will go away. Any ideas wh
sounds like the wheels are out of balance, is there a slight vibration through the steering wheel at this speed? and does the problem stop if you go faster (please drive carefully)
2answers
Buzzing sound under dash of 95 jeep grand cherokee
There can't be any noise after 5 minutes. There are capacitors that take a few minutes to drain down. It could be your clock winding or your abs cycling. Listen and see if it's coming from your fuse box a relay
2helpful
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
7helpful
3answers
Buzzing sound
Re:- the buzzing behind the dash:-
Its tiny a fan which carries on running in humid conditions to circulate the air so you dont get blasted by warm air when you use your climate control.It circulates air across the humidity sensor. It keeps running for a while after you switch off, and starts again when you open a door. It does this so that there is less delay in getting the climate control to the right setting when you switch on (or restart).
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
