Need a wiring diagram 4 a goodman self contained it a 96
The fans not kickin on so I need a wiring diagram just to make sure no wire are crossed I believe it's the compasitor for the fan motor
  • 8,220 Answers
Remember this: The fan is usually set for low (red wire on the fan motor) for the furnace. The fan must blow on high(black wire) for AC and they do that by mounting a relay on the fan center in older units. Newer units do it by the a computer board. If your unit has a fan center the relay mounted on top of it is probaby fried.
need a wiring diagram 4 a goodman self contained i - 495e425.jpgsome of the units have a smaller one called a peanut:
Posted on May 14, 2009
  • Dan Webster
    Dan Webster May 14, 2009
    Google a 90340 and a 90370 to see these relays. Dammit I posted pix but they did not show up.
  • Dan Webster
    If you fan relay is burnt up that fan won't kick in . HERE is a pic
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
Mar 19, 2017 | Goodman Heating & Cooling
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Jun 27, 2008 | Goodman Heating & Cooling
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
I need a diagram for the wiring for a Goodman blower fan control
The best place to find the correct wiring diagram is on the back of the blower compartment cover...all furnaces have the wiring diagram right on the back of the cover....
heatman101
Feb 08, 2011 | Goodman Heating & Cooling
Ive installed a new capacitor on my 3ton unit,now the breaker keeps flipping.I think i may have my capacitor wires cross! please help!!!!!!!
A cap for just the comp, one wire form the contactor to the cap and the other wire to the comp, there should be a wire diagram. if it is for the fan and comp it will be lable fan,com,comp. one wire3 from the contwctor to common, the fan wires one to common and on to the fan side. The last on for the comp
Jul 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Firing order diagram 96 dodge ram 1500 i think i got some plug wires crossed need to know where 4 sure they go a picture or diagram would be a great help
There were three different engines for that vehicle in 1996, here are diagrams of the 3.9 liter V-6 engine, and the 5.2 and the 5.9 liter V-8 engines both have the same firing order.
3.9 liter V-6 liter engine;
5.2 liter/5.9 liter engines;
May 23, 2010 | 1996 Dodge Ram 1500 Club Cab
Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Replacing old 3 wire condensor fan motor with new 4 wire
the new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
May 08, 2009 | Goodman CLQ36AR49 Air Conditioner
10 kw heat with 2 speed fan
Checkout GOODMAN ELECTRIC FURNACES . website.
Sep 02, 2008 | Goodman CKL36AR36 Air Conditioner
Heating & Cooling Logo
191 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
