Question about Compaq Armada M700 Notebook
My compaq armada m700 says the video driver will not initialize
My old compaq armada 700 will turn on and boot to windows but then it restarts and says the video driver failed to initialize. i did take the dvd drive out while the computer was on did that mess it up
  • dhdjad May 11, 2010
    probably not. do you get any picture at all?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the device manager and let me know what it has installed as the display adaptor.
How do i get to the recovery partion on compaq armada m700
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
May 16, 2014 | Compaq Armada M700 Notebook
Installed a new hard drive (old one missing) and tried to load windows vista and nothing happens
You might need to go into "setup" when your computer boots up and change the boot options so that it boots first from CDrom and hard drive second. This should allow it to boot off the Windows CD. That will start your Windows setup program.
Nov 28, 2009 | Compaq Armada M700 Notebook
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
System options not set on a compaq Armada m700 laptop
HI mrwiggley,
What Systems Options are you referring to pls?
As long as no major hardware problems, then yes, normally the user can configure Windows XP to perform to your preference.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Compaq Armada M700 Notebook
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
takecare.
Apr 28, 2008 | Compaq Armada M700 Notebook
Keyboard problems
You need to download and install the proper drivers from Compaq (now HP). Go to http://www.compaq.com and do the following:
Click "Get Support" at the top.
Enter "armada m700" in the "Enter a product number" box.
Click the little submit button that looks like ">>".
Click "Download drivers and software".
Click one of the "Windows XP" links. Doesn't matter which one.
Scroll down and click the "Download" buttons that correspond to each driver you want to download.
Install the drivers you downloaded.
Feb 02, 2008 | Compaq Armada M700 Notebook
Code 10 error over my network adapter in device manager
Compaq armada m700
might have to do a windows repiar with xp cd or formatt it all install fresh copy
Jan 26, 2008 | Compaq Armada M700 Notebook
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
190 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
