Question about Brother DCP 130C All-In-One InkJet Printer
Clean unable 46
Brother 150C notice : clean unable 46
i don't understand this notice . Plz help me
  • 433 Answers
You need a new ink absorber box which can be purchased from a brother service partner near your home.
www.brother.com
If you have got the spare part (ink absorber box) you have to open the printer:
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
Posted on May 14, 2009
Brother dcp-150c unable clean 46.how can troubleshoot this problem? plz help me. thanks
To help you troubleshoot the error 'Unable clean 46', please follow the instructions given below:
- Pull out the AC plug.
- Put back the AC plug while holding down the 'Menu' button and keep holding it (15 sec).
- Now you are entering the 'MAINTENANCE' mode and 'Error 46' pops up in the display.
- Select 8 by using the arrow buttons ,push OK and select 0 and push OK.
- 00:00 00:01 OK (the display is showing this message).
- Now push the 'MONO' button 25 times until you see PURGE: xxxxx
- Select 2, push OK, select 7,push OK,select 8,push OK, select 3,push OK.
- The purge counter indicates now: purge: 00000
- Switch OFF the printer and wait for 1 minute and Switch it ON.
- Now try to print.
If issue persists, it is recommended to contact Brother Support Center for further assistance from the link given below:
http://support.brother.com/g/b/contact.aspx?c=au&lang=en&cid=2&pcatid=4
GuruAid.com
Jun 08, 2016 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
CLEAN UNABLE 46
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Feb 25, 2011 | Brother DCP 130C All-In-One InkJet Printer
Brother dcp-150c Clean Unable 46
If you actually changed the flushing box, you should know how to go to the maintenance mode and reset the waste ink counter. Info. that is only available to Brother techs.
Jul 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
My Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
Jul 22, 2009 | Brother MFC-5840CN All-In-One InkJet...
Error 46 and says unable to clean. can u help me plz
According to the manual, the unable to clean error means a mechanical problem or a foreign object in the machine: Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002010/BH3eDCPWLAN_UkEngUsr.pdf
Apr 24, 2009 | Brother DCP-340CW All-In-One InkJet...
Unable to clean
plz search this forum for unable to clean or error 46
it has been explained so many times
Apr 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
664 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
