Question about Kenmore Washing Machines
Wont spin and makes a buzzer bell like sound while in rise and spin modes Does washer have a reset button ?? The water fills in no matter what setting and even if you run without clothes makes a buzzing or alarm like ringing souund will drain water but will not agitate or spin
  • 47 Answers
PROBAB;Y YOUR MOTOR COUPLING.
Posted on May 14, 2009
Why doesn't my washer drain?
Sounds like your pump is out.
Jul 13, 2014 | GE GTWN5050MWS Washer
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer won't spin or agitate
what brand? model name and number would help. it might just need reset. or could be other problem.
Jan 26, 2014 | Washing Machines
Washer will not spin
my washer wont spin or move water fill up but wont do nothing
May 01, 2012 | Estate ETW4400VQ Top Load Washer
I am having difficulty with my washer. once i put it in wash mode (doesnt matter the water level) it starts filling up with water and WONT stop. it has overflowed a cpl times on me. when i turn the knob to...
If your washer just keeps filling it and the pressure valve is not to blame I would suggest that your tube coming off of the pressure valve might be blocked or partially blocked. If you have hard water where you live try taking off that line (it just pulls off fairly easy) and squirt some CLR into the tube. A good way to check to see if there is any restriction is when you take off that tube. You should be able to blow though it very easily.
Aug 16, 2017 | Crosley CCW5294W Top Load Washer
My GE washer model WDSR2080D2WW, will fill and wash only. When it should drain and go into the spin cycle, all it does is makes a buzzing noise from the timer. This is no matter the cycle setting. What is...
Hi- Sounds like your drain pump is bad, or clogged. Not easy to get to. It could also be a timer issue or an issue with your pressure switch which tells the washer when the water is out and it can go into spin mode. Sounds like you need to have someone out to take a look.
Sep 23, 2010 | GE WDSR2080D Top Load Washer
My Kenmore 70 is also overfilling...
Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Washing Machines Logo
119 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
