Question about Microsoft Windows XP Home Edition Service Pack 3 Full Version OEM for PC
I want to disable system restore for Windows XP v 2002, Service pack 3. It is not identified in ctrl panel -> system -> perf tab - (in fact, there is no perf tab) > file system -> trbl shooting. Where the heck is it?? Thanks much
  • jfly52 May 14, 2009
    Thanks much - but now it tells me Syst restore has been turned off by group policy, check with administrator - I used to be the administrator.
  • 15,935 Answers
Start
all programs
accessories
system tools
click system restore
left side click System Restore Settings
check box - turn off system restore on all drives
thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 14, 2009
  • blueextc3221
    blueextc3221 May 14, 2009
    yes - you must be signed on as the administrator to complete this.
How do i make my pc fster
Slow Windows Machine! Try disabling startup programs. Go to Start > Run and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM.Uninstall any extras like those pushy toolbars, and add-ons.
Dec 06, 2012 | Microsoft Office 2010 Professional 32 64...
HP xw8200 overheating
Overheating is more likely to cause a shutdown. You need to do some troubleshooting. Remove all USB attached devices. Roll back system with System Restore under Safe Mode (press F8 during boot and choose Safe Mode). For Win 7 - Start > Start > Search type System Restore. For XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem starting. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
Disable startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. In fact, in your case uncheck all. TEST.
Oct 11, 2012 | HP xw8200 PC Desktop
While tring to install my UM175 modem, I get a message that say OS not supported. What do I do?
The Verizon UM175 installation supports WinXP, WinVista, and Win7 (and you're certainly running one of these three), so the only possible problem you might be having is that you may be running Windows XP, but you're running a Service Pack level that is no longer supported. Most software packages require WinXP to have at least Service Pack 2 installed, and many installations are now requiring WinXP to have at a minimum Service Pack 3.
To determine what Service Pack you're running:
START > Control Panel > System > General (tab)
Microsoft offers "Service Packs", consisting of (free) packages of updates and bug fixes for its operating systems, which are released riddled with bugs, omissions and security holes.
To install the Windows XP service packs that may be needed to allow the Verizon UM175 modem-related software installation to proceed, visit Microsoft at:
http://support.microsoft.com/kb/322389
This Microsoft Knowledge Base article mentions Service Packs 1, 1a, 2, and 3, but there is also a 4th.
Windows Vista also has service packs (there are two). If you're running WinVista, the Verizon software may require both. For these Service Packs, visit Microsoft at:
http://support.microsoft.com/kb/935791
Oct 03, 2011 | Computers & Internet
MY MOUSE IS STUCK ON MAGNIFY
I had this problem once. It was because I had held the SHIFT key for 3 seconds, and it had entered disability mode. It's either SHIFT or CTRL.
You could disable it completely in Start -> control panel -> Accessibility options
Feb 10, 2011 | Microsoft Windows XP Home Edition
I can't turn on windows firewall. respons message: windows cant running ics service
The Windows Firewall Service not started.
Now to fix:
1. Click Start > Run > Type services.msc
2. Scroll down to Windows Firewall/Internet Connection Sharing (ICS)
3. Double click it.
4. Change startup type to Automatic and Click Start.
5. Click Apply and then OK
6. Reboot.
To reset the Windows Firewall to the factory default state, try this:
Type firewall.cpl in Start, Run dialog.
Click the Advanced tab.
Click the Restore Defaults button.
Click Yes to continue when you see this dialog
Restoring the default settings will delete all settings of Windows Firewall that you have made since Windows was installed. This may cause some programs to stop working.
Alternately, you can use the NETSH command-line to accomplish this:
Open a Command Prompt window and type NETSH FIREWALL RESET
This command resets firewall configuration to default. This provides the same functionality as the Restore Defaults button in the Windows Firewall interface.
or
Try this link @ http://support.microsoft.com/kb/914230
Hope it helps.
Note:- If you PC is infected with Malware & Spywarea that disable you have to clean up your PC first!!
Nov 14, 2010 | Microsoft Windows XP Home Edition Service...
How do i find and select ports? Windows XP Prof.version2002 ser.
you can find the available ports in Start >Settings> Control Panel > System> Hardware > Device Manager. But selecting the port would depend on what application/hardware you are trying to select it for.
Jan 25, 2010 | Computers & Internet
Loading win xp gives message script file cleanvirus.vbs not found
Disable System Restore. Scan your computer with the free version of Malwarebytes' Anti-Malware.
http://malwarebytes.org/
If you don't have an Anti-Virus program, download Avast and scan.
http://www.avast.com/
If both scans don't detect anything, do this..
Ctrl-Alt-Del > Processes - End the following processes in order:
dxdlg.exe
wscript.exe
Start > Run > regedit - Open the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\Windows NT\CurrentVersion\Winlogon
In the right hand pane, select Userinit and delete everything except C:\windows\system32\ userinit.exe
Make sure the processes wscript.exe and dxdlg.exe are not running.
Delete the following files
C:\Windows\System32\dxdlg.exe
C:\Windows\System32\boot.vbs
In your Windows drive, search for boot.vbs and delete all of them.
In your Windows drive, search for kinza.exe and delete all of them.
Enable System Restore.
Restart your computer.
Nov 28, 2009 | Microsoft Windows XP Professional With...
System Restore Problem
Follow the instructions below to disable System RestoreDisabling System Restore on Windows ME
1. Click Start, Settings, and then click Control Panel.
2. Double-click the System icon. The System Properties dialog box appears.
NOTE: If the System icon is not visible, click "View all Control Panel options" to display it.
3. Click the Performance tab, and then click File System.
4. Click the Troubleshooting tab, and then check Disable System Restore.
5. Click OK. Click Yes, when you are prompted to restart Windows.
Once you have cleaned the virus or other problem from the computer, reenable System Restore by following these directions
Oct 18, 2008 | Televison & Video
System Restore gets disabled
You must set the "Service" to "Automatic" here are some instructions. And a link to a M$ KB article about it. support.microsoft.com/kb/302796 Start the Group Policy Editor (gpedit.msc) Navigate to Computer Configuration/Administrative Templates/System/System Restore Set Turn off System Restore and Turn off Configuration to "Disable" Right click on My Computer and Select "Manage". Navigate to Services and Applications/Services Navigate to System Restore Service and double click On the General tab set [Startup Type] to "Automatic" using the drop down list Click the Start button to start the service. Close the Computer Management console Return to System Restore in Group Policy Editor and configure both to "Not Configured" Close Group Policy Editor and reboot the system. After the reboot is complete, right click My Computer, select Properties and the tab for System Restore will have been restored. Configure it to your individual needs.
Aug 20, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Service Pack 3  Full Version OEM for PC  Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
