Question about Regal Ware K6725 Kitchen Pro Bread Maker
Bread pan shaft hard to turn
The bread pan shaft will not turn. Best way to remove shaft and clean seal.
I had the same type of problem with mine and found out you remove the kneading part that spins and pull up the seal underneath. You will probably find dough has gotten in under the seal somehow and caused problem. I just took a toothpick to it and voila! Trouble is you have to be careful not to damage the seal by taking it out...
Posted on Jun 14, 2009
How do I get spare parts for a bifinett bread baking machine KH1170
Really by the time yo find a part and pay shipping and handling you may be better off to trash it and buy a new machine on sale.
Best wishes
Nov 05, 2014 | Breadman Bifinett Kompernass Bread Maker...
I have this machine for 4 years now and I was happy with The central shaft does not turn now and I lost all my stuff... It makes the noise like if it works, but nothing happen... and there is a...
Hi.. The "central shaft" could mean the motor shaft is not turning or the "central shaft" could be the paddle shaft in the bread pan is not turning. If it's the motor shaft then tighten or replace belt. Since you "lost all your stuff" it could be the sealed bearing in the bottom of the bread pan has broken. The paddle doesn't turn and is leaking. If this is the case the bread pan needs replacement. Hank
Jan 18, 2011 | Black & Decker B1561 Bread Maker
I think the bearing that turns the blade in my magic chef breadmachine has gone bad, very stiff turning. Can I get a part for model # VBM200C-1(200)?
find A SIMILAR BEARING ON BERINGS STORE, GO WHIT THE BERING TO THEY, OR READ ON THE BEARING THE NUMBER: EX: 506, 6001, 6201.....ETC,
Feb 14, 2010 | Magic Chef CBM310 Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
Hitachi HB C103 bread machine pan seal
The problem isn't the seal, it is the bearing. You need to disassemble it, clean it, and lubricate it. Turn the pan upside down, and there's a C-ring that you need to pry off. Then you can tap the shaft through the bearing, and it will fall out. Clean the shaft and inside of the bearing, lubricate it, and reassemble.
I usually lubricate with vegetable oil, to avoid any chance of noxious contamination getting into the bread, but I've read a recommendation to use liquid graphite lock lubricant, available from NAPA Auto Parts, to prevent the bearing from sticking again as soon:
http://reviews.ebay.com/How-to-lubricate-your-bread-machine-pan-shaft-bearing_W0QQugidZ10000000016577277
BTW, be careful of that rubber seal -- they are apparently irreplaceable! (I need one, if you find a source.)
-Dave
http://www.burtonsys.com/email/
Oct 28, 2009 | Kitchen Appliances - Others
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Nov 22, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Hitachi bread maker
I had the same problem after storing my machine for several years, BUT, I lucked out...I just added a little warm water to my pan and then turned the machine on and let the paddle turn a few rotations and walla!!....it freed itself and is now making great loaves once again!
Jan 26, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Shaft not turning
Unfortunately Regal ware no longer supply spare parts for there breadmakers, because their motto about dedication obviously didn't apply to bread machines. I think youe best bet would be to take the pan and machine to a local machine shop and see if they could make you one up - if they could it shouldn't be too expensive. Hope this helps :)
Feb 13, 2007 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
191 people viewed this question
Top Regal Ware Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Regal Ware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
