Question about Samsung SV5000W VHS VCR
FLASHING 2 on hitachi FX6500 VCR - Samsung SV5000W VHS VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
TV (Hitachi CT2043B)/Satellite
Yes.
1) Connect the cable from the Satellite to the input of the VCR
2) Connect the VCR Output to the TV (Either Coax or RCA).
3) Tune the VCR to Channel 60.
4) Enjoy your Satellite programing...
Good Luck....
Jan 19, 2010 | Hitachi Televison & Video
Intructions for programming a remote control
I own this remote. Here are the instructions.
1 turn on your tv or catv
2 aim remote at tv or catv
3 while holding tv or catv button press 0 to 9 last ch 100/ent or channel
4 release both buutons when tv or catv changes channel.
note press tv or vcr or catv button first to select desired function
Mar 06, 2008 | Hitachi VT-RM380A Remote Control
Hitachi vcr fx6505
you need 2 pairs of audio/video cables
from the back of ur tv set you can see (audio out---video out)
now insert cables in your tv set.. then connect to your vcr (audio in---video in)
vice versa vcr to tv----tv to vcr
Jan 29, 2008 | Hitachi VTFX6510A VCR
Hitachi VT-FX240E
press the operate button fo rmore than five seconds as video is in parental mode
Jan 27, 2008 | Hitachi VTFX65SK S-VHS VCR
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
Problem with my vcr Hitachi VT-MX 848E(AU) G-code
What speed are you recording at? VCR's with more than 2 heads use different heads at different speeds. Try recording at all speeds and see it that makes a diference on playback.
Oct 31, 2007 | Hitachi VTFX6510A VCR
Does not accept the video cassett
VCR....yowser...when you put the tape in does it look like its goign to load and then it either spits it out or just starts flashing? I smell smoke on this one. as in toast
Aug 27, 2007 | Hitachi VTFX665A VCR
Flashing "1"
It could be a defective loading motor, jammed mechnism or defect in the power supply. Probably cheaper to replace the VCR.
Jan 13, 2007 | Hitachi VTFX685A VHS VCR
Samsung SV5000W VHS VCR Logo
224 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
