Question about Casio Exilim EX-V7 Digital Camera
My pictures were not saved on my SD card so where did they go if they did not go in my internal memory?
  • 407 Answers
They may have been saved to the camera memory - Most cameras have a limited amount of internal memory - If they ae saved to your camera and not SD card, you can still transfer to them your PC via USB cable.
You can check where the photos were saved to by checking the settings on your camera/ menu/ settings/ default
Posted on May 14, 2009
Says memory card error and internal memory full. sometimes will recognize sd card but when picture is taken it either freezes camera or says no image/sound
It sounds like the camera is set to always save to the internal memory. With the SD card in place, adjust the settings to save to the SD card. (Sorry, I don't know the exact menu paths for your camera).
(If you have also copied your pictures off your camera, you can erase the internal memory and use that to take more pictures - however it will fill up again).
Nov 21, 2015 | Pentax X90 Digital Camera
Photo not saved in internal memory
You have to set your camera to save to internal memory... It usually does so when you take the SD card out... It will then default any pictures to internal memory... If you set a picture as a screensaver it will automatically be saved on internal memory too.
May 09, 2012 | Cameras
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
Doesn't recognize memory card. I had an Eye Fi wireless memory card installed and now it's totally blank and the camera doesn't recognize it. Tried a regular SD memory card, and the camera doesn't...
Your camera is only supporting SD/MMC Cards (up to 2 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 23, 2010 | Kodak EasyShare Z740 Digital Camera
IF IT COMES INTERNAL MEMORY FULL EVEN IF THE MEMORY CARD IS 2GB WHAT SHOULD WE DO
How to switch the camera over to saving pictures directly onto the SD card.
  1. Menu
  2. Cam settings
  3. Chose AUTO or SD card option and Press OK
Jan 18, 2010 | Kodak EASYSHARE M763 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
      1. Menu
      2. Cam settings
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I have a new memory card. I cant get pictures
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    DC6550
    We need to be sure of some things:
    Are you saving the picture to the internal flash memory or an external SD card?
    1) The internal memory will only hold 16MB of pictures, check if it's full.
    2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
    1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
    2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
    Does this help you in any way?
    Please give us more information as to how you are saving them and/or any further questions you may have.
    Dec 12, 2007 | Cobra Digital DC6550 Digital Camera
    Casio Exilim EX-V7 Digital Camera Logo
    182 people viewed this question
    Top Casio Cameras Experts
    mohamed salim shaikh
    pontelemon
    pontelemon
    Are you a Casio Camera Expert? Answer questions, earn points and help others
