Question about Craftsman Garden
TRYING TO REPAIR A CRAFTSMAN 4 CYCLE STRING TRIMMER MODEL #358.796121. I GOT THE CLUTCH HUB OF BUT CANNOT GET THE NEXT PART OFF. THE PART IS THREADED ONTO THE SHAFT AND SHOULD PROBABLY TURN COUNTER CLOCKWISE. I CAN'T FIGURE OUT HOW TO KEEP THE SHAFT FROM TURNING.
  • 246 Answers
Hello kane8:
**To Hold the Crankshaft for Removal of the Clutch (or Any Component that Turns with the Crankshaft); Purchase a Bolt that is 3" to 4" Long and has the Same Diameter and Threads as the Spark Plug. Carefully Insert the Bolt Into the Engine Until it Contacts the Piston. If the Bolt is too Short, then Slowly Turn the Engine in the Same Direction you are Going to be Turning the Clutch Until the Piston Contacts the Bolt. Now to Remove the Clutch. If you do Not have the Clutch Tool for an Impact Wrench and are Doing this By Hand (no air compressor and/or not the correct socket), then Use a 2" Wide, Flat Chisel and a Shop Hammer or a 22oz Hammer and Hit the Outer Part of the Thick Ear in the Same Direction that the Engine Turns During Operation.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
I have a craftsman trimmer and removal of the hub has proven difficult. Is there a method that I'm missing from the procedure?
By referring to "hub", do you mean the string head at the end or the round metal clutch drum at the end of the crankshaft? Post back as I would like to help.
Sep 30, 2010 | Craftsman 25cc Gas Line Trimmer
Putting new pull string on Craftsman trimmer
it does screw on take a channel lock to grab the clutch and turn left to remove it
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Repair a weed trimmer, How to remove the starter clutch
down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
May 13, 2009 | Craftsman Garden
Garden Logo
174 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
