Question about Husqvarna Sewing Machines
The needle in the C slot of my Husquavarna 936 won't stay in
The needle in the C slot of my Husquavarna 936 Serger will not stay in place when it has been reinserted after working in a 3 thread mode. The set screw appears to be fine but will not tighten against the needle. I have tried different needles and the problem remains. Any ideas?
  • jrattt May 19, 2009
    Thank you.  I will pursue changing the clamp.
  • radcal May 11, 2010
    Are your C and D screws both on the right side of the clamp, one above the other or do you have one on the right side and one on the left? If you have one to either side, you may want to have the clamp replace for the more modern design.
    Novelist:
  • 152 Answers
Make sure you have backed out the screw almost all the way, grab the needle with a pair of needle nose pliers and push the needle up with "gentle" force to make sure it's up all the way. When you tighten the screw without a needle in the hole (when 3 thread sewing) the screw makes an indentation inside the needle hole. That indentation stops the needle from reaching it's upper most position. By "gently" forcing the needle up in the holder all the way, you correct the opening for the needle by breaking out that tiny imperfection. Your needle screw then can hold the needle correctly.
Posted on Oct 10, 2009
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
Loose Needle
Needle clamp probably cracked through overtightening
Jan 30, 2014 | Husqvarna Huskylock Computerized 936
FS320 serger needles won't go up and down. New
if the machine is still under warrenty, take it back
if it's not under warrenty, take it to the place you bought it from & tell them
May 28, 2012 | Yamata Sewing Machines
I have a viking serger 936. I do not understand the threading for the cover stitch
http://www.sewingresourcesonline.com/product/PD1234
I have the same serger.  The produt link posted above is an awesome intrustional dvd on learning the cover stitch.
Feb 14, 2011 | Husqvarna Huskylock Computerized 936
I also have the same problem for the cover stitch i put the needle in the holes for A and B and unscrew and slide the needle in flat side of needle to back but the needle does not go up all the way and i...
The best needles to use in the Vik serger is the Schmetz brand. Also, loosen the right needle a bit to make sure you are getting the left needle up all the way, tighten left, then tighten right.
Feb 06, 2011 | Husqvarna Huskylock Computerized 936
I cannot get the needles to stay in my Huskvarna Huskylock 936 serger. How can I get them to stay in?
I would say it is 2 things, first you don't have the screws loosened enough to get the needles up and in far enough, then make sure you have tightened them up enough, this should solve your problem. Also, the flat of the needle goes toward the back of the machine.
Sep 17, 2010 | Husqvarna Huskylock Computerized 936
Hi there, my husqvarna 936 is jamming slightly when i turn the hand wheel and when i use the pedal it works but their is a load catching noise can you help me plz
Hello, The first thing to do with a serger is to change the needles and take the thread off the machine and rethread it. The 936 can sometimes "fight" you a little when it comes to getting the needles up in all the way. It's critical that they are inserted all the way up in the needle clamp. Check to also make sure the N/R lever is in the N position. Check the needle plate, are the "needle like" pins still attached to the plate? If your serger jammed, sometimes the thread breaks the pin supports out of the plate. They are very important when it comes to stitch formation.
Oct 06, 2009 | Husqvarna Huskylock Computerized 936
My Husqvarna 936 Serger is giving me a "overloaded" message on the screen. I am serging the edge of a sheet. Please advise.
This happened the first time I used a 936. I had borrowed it from a friend. Fortunately she was with me. the dealer found it needed to be oiled in places amateurs should not go. That was all it took. Oiling all the moveable parts.
Apr 15, 2008 | Husqvarna Huskylock Computerized 936
Sewing Machines Logo
143 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
