Question about Akai LCT2060 Television
Akai color tv was working fine but when cable went digital the (v-chip 4 code blocker) kicked on blocking with a black box covering 3/4 of the blue screen.It is scanning for a four digit code.*We can not find the original manual. Any one know the code? Thank you! MA.
  • machopperman May 14, 2009
    Thank you .I am going to try then right now!Michael.
  • 934 Answers
It sounds more like you have the closed caption selected in the customer menu - you might check that first.. If not you can easily contact Akai customer service at http://www.akaiusa.com/ for any issue including a replacement owner's manual...
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on May 14, 2009
Hey everyone. I have a Hitachi Rear projection Tv 53udx10b. I just replaced the convergence chips and cleaned all 3 CRT tubes. The picture definitely looks clearer now but the white tint has a slight...
You can try adjusting the color output. There are two ways to do this:
1) In the service menu (I don't know the codes or parameters...) I will not cover this for lack of info.
2) Via the focus block (Very touchy and difficult to get the mix right again if you get too far off)
If you take off the front cover there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need more red in the mix or just less blue and green. There is a screw for each color. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Barely turn the red up.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn andy of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Televison & Video
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
I have a Akai DVDrw125. I've never been able to connect it between the cable signal in and the TV. It has S-Video in and S-Video out. The manual is worthless. I shouldn't have to switch the S-video cable...
The way I have it set up - cable box out to AKAI cable in, video and audio out of AKAI into TV via RCA. AKAI on channel 3, tv on RCA input. Change channels on Cable box, works fine. To watch a video, just put it in an hit play. Might have to change sources on AKAI if this is not working for u.
Mar 03, 2009 | Akai DVDRW120 DVD Recorder
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Digital conversion tv no color
if it is connected with coax cable i would first try removing the cable and reinserting it, try putting the channel switch on 3 instead of 4, or 4 instead of 3, if this does not work try a different coaxial cable
Aug 06, 2008 | Televison & Video
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Akai LCT2060 Television Logo
182 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
