Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Need better instuctions to install compressor start device/pictur
Instructions i have with the new parts make no sense !
    President:
  • 1,136 Answers
Hi, What parts are trying to install. I will try and assist you.
Vic
Posted on May 14, 2009
Spitting and sputtering
there are 2 sensor to buy,
PNP (just pull them in, plug and play)
or hand wired, you by the much harder hand wired sensors>
post maker of new sensor and part number and i can look it up.
bosch sensors have and installation instuctions in the box.
you by china clone parts. ? noname parts/? if yes, ask them.
Mar 05, 2013 | 2004 Suzuki Verona
Install whirlpool starter/relay kit
you should of ordered part number 8201786 and this is the whole start device that slides onto the compressor,this replaces the overload and relay and it's around 60 dollars. http://www.searspartsdirect.com/partsdirect/part-number/8201786/0046/106?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=8201786 unplug it,pop the clip off and remove the cover,slide off the device,read instructions, wire it,slide the device onto the three pins on the compressor,put the cover and clip back on and you're done.hope this helps and good luck with your machine
Nov 16, 2011 | Refrigerators
How to turn on bluetooth
Hi.........
Hello........
Try looking around in the Control Panel. The "classic view" might help you find exactly where it is located.
These computers can be made with Bluetooth, but it is still an option, so you may or may not have it. If you don't, small USB adapters are available anywhere that sells electronics (Target, Wal-Mart) for about $20 if you really need it. Bluetooth is slower than a direct USB connection, so if its not too much of an inconvenience, a direct USB connection might work better anyway.
Regardless, here are the instructions I found for installing a Bluetooth device on your laptop:
To install a Bluetooth enabled device:
a. Set up the device so that your computer can find it. To do this, you must:
i. Turn the device on.
ii. Make it discoverable.
b. Click the Start button Picture of the Start button, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
c. Click Add, and then follow the instructions.
To install a Bluetooth enabled printer:
a. Open the Add Printer wizard by clicking the Start button, clicking Control Panel, clicking Hardware and Sound, clicking Printers, and then clicking Add a printer.
Good luck.......
Sep 21, 2011 | Amstron Dell Studio 1537 Laptop AC Power...
My Haier refrigerator, model # AES44W, the compressor will not start. The relay keeps clicking apparently to keep it from damaging the compressor. Do I need a new overload protector as it does not have a...
This sounds like the relay has gone on the compressor. Call your local appliance parts store
(no model no. needed) and ask for a hard start kit. Instructions are on kit.
I use ERP 410 powerstart relay capacitor and over load. See it has everything and is much better than the original.
Remove the back cover, pull the original relay off the compressor pins, cut the two wires and install according to instructions. Very easy job.
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED
Aug 05, 2011 | Haier Refrigerators
Clicking noise when starting
Leo Ponder
imufo2
May 27, 2011 | Refrigerators
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Hi, freezer took a dump two days ago, fridge was still fine. Then 12 hours later the fridge dumped out too. The compressor is hot and the relay looking thing with part number nsk 85851 clicks on for 20 sec...
most likely the start device is bad,look at the left wall inside the fridge near the cieling,you should see a model number,call your parts store,give them the model number on the machine,there is other letters after the g and tell them you need a start device.unplug the machine,until you get the part so you don't damage the compressor,it's not cooling anyway and thhe freezer feeds cold air to the fridge side,a fan blows cold air from freezer to fridge so next time if the freezer has a problem the fridge side is gonna have a problem too,unclip the metal clip and slide the start device off,read the instructions and it will tell you how to install the new device
Feb 06, 2011 | Maytag PTB2153G Top Freezer Refrigerator
My whirlpool fridge freezer won't turn on and it keeps tripping the house fuse
It is quite possible that your compressor motor is loading up and using more amperage than is required. hence the trip happens on start up. Try to change the main capcitor to the motor and test. If your cooling is fine and the freezer is working in order then this would solve. if not the compressor is defective and will need a change. But you will have to weigh the cost of changing to a new model with energy saving and warranty. So check this out. Good day
Jul 13, 2010 | Whirlpool GD2SHGX Refrigerator
Neither the freezer or the refrigerator is cooling. Repairman replaced the relay switch, but this was not the problem. After installing new relay switch, repairman said he could not hear it click or whine....
Yes, there are two are actually 3 parts. Its probably NOT the compressor. You need a three in one start kit which is pretty much a turn key part if installed properly. Its basically a start relay with the capacitor for the starting and running of the compressor. Alot of time the relay will go bad because w/o the start assist it has trouble, pulls a high load burning up the relay in the starting. Its a much better part than the original, in 20 years I've yet to replace one put on a whirlpool.
Jul 12, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Intalling the belt without a/c on a 1995 GMC Jimmy
The item you are looking for is call
A/C Compressor Bypass Pulley
DORMAN Part # 34152 {HELP! - Boxed #10118713}
Picture link HERE
Major vendor HERE
Dec 08, 2009 | 1995 GMC Jimmy
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
233 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
