Question about Jensen TS2750J TV
Jensen model TS2750J
What would cause the or any remote not to work on Jensen ts2750j model? I have bought 4 different remotes and none of them have worked. Should there be a light sensor light showing just above the +Channel button. Can this sensor be found and replaced easily?
  • 4 more comments
  • Anonymous Jul 05, 2008
    I cannot find a remote control that will work with my TS2750J TV. I have bought three remotes and none of them will program.
  • bettydianna Jul 05, 2008
    I have purchased three remote controls and none of them works with this model.
  • Anonymous Jul 19, 2008
    what would cause the or any remote not to work on Jensen ts2750j model? I have bought 4 different remotes and none of them have worked.
  • cgonsalves Jul 27, 2008
    I have the remote problem too.
  • carache Aug 06, 2008
    I have bought 2 different remotes and none of them have worked.I test this device in other tv and work ? can you help with the right code for program my control tv ?
  • brattipatti Mar 20, 2009
    None of the remotes I have work with the Jensen TS2750J. Now the remote that it came with none of the buttons are working. I tried new batteries but every button you push makes the caption option come up on screen. WEIRD. This TV has been a problem since I bought it. I will never purchase another Jensen TV again. Seems like I'm not the only one.
Tv locked and I cant get it unlocked
Posted on Mar 28, 2008
How to unlock jensen TS2750J parental control lock?
Hello
To unloxk your Jensen TV do the following.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
OK.
Feb 22, 2011 | Jensen TS2750J TV
Locked tv
this happen to me a couple times before if remember you need the orginal remote then hold down menu and another button sorry i dont remember which one sorry hope this can help
Mar 10, 2009 | Jensen TS2750J TV
Jensen t.v model ts2750j blue screen red lock upper left
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Feb 02, 2009 | Jensen TS2750J TV
Does my Jensen TV TS2750J have a digital tuner?
I called another aervice, they responded in 10 minutes, my TV does Not have a digital converter but it will work with any cable company after February 2009.
Dec 11, 2008 | Jensen TS2750J TV
Remote Control
GE Universal remote control is fit for your jensen tv
Thanks!
Jul 05, 2008 | Jensen TS2750J TV
Wont turn on. Jensen TS2750J
We have the same problem if you find out how to fix it please share ......
Dec 29, 2007 | Jensen TS2750J TV
Lock jensen ts2750j
press the diplay button for 3 seconds
Feb 25, 2007 | Jensen TS2750J TV
JENSEN TS2750J AUDIO NOISE AFTER WARM UP
That is about the time it takes a component to heat up again and show a problem,it seems you have isolated the problem good just make sure the components around the Ic are not getting cool too because it might be one of the,if you are sure nothing else is getting cool check the solder conections on the chip and if they are solid just replace the IC.Is a good place to start.
Sep 20, 2006 | Jensen TS2750J TV
Remote Code
Try the JVC and sharp tv codes. I have found some jensens were made by jvc or sharp
Mar 31, 2006 | Jensen TS2750J TV
Televison & Video Logo
196 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
