Retrieval of fax from memory
Fax reportedly sent 10 days ago but lost. Sender shredded his original.Is it possible to retrieve the fax from memory.Memory journal report of the fax ,only providing 3 days summary.Can we get report of incoming faxes from an earlier date?
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
Posted on May 16, 2009
Can I reprint an out going fax?
Yes it is. Go to memory and find the # for that fax. Then print that from memory
Oct 20, 2015 | Canon imageCLASS MF6550 All-In-One Laser...
I am trying to retrieve a fax from the memory that was sent to me a couple weeks ago, is this possible?
Hi there!
It is possible if the fax storage of your fax machine is on. To check if its in press Menu 2 5 1, the lcd should show fax storage. and to print the fax press Menu, 2 5 3 to print the stored fax.
If the lcd shows off when you press Menu 2 5 1 there is no way to print that fax.
Hope this helps. Rate if it works. Thanks
Mar 31, 2011 | Brother MFC-8460N All-In-One Printer
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Aug 05, 2010 | Brother MFC-8840D All-In-One Laser Printer
I need to retrieve the image of a fax that I sent
In the Fax reports menu, you can select the fax log and it willl have the number you sent to, but the image is gone as soon as you fax it.
Jul 02, 2009 | Office Equipment & Supplies
Need to confirm details of when and what number a fax was sent approx 15 days ago.
The only way to check old transfer info for faxes is by printing out the journal. The way to do this varies from fax to fax, but most often is either with it's own button "reports" (and then "fax journal"), or by choosing "print reports" in the regular menu. The journal is emptied during power outs, so if you have had a power failure since, you cannot get the information. Additionally, the only info you will get from this is to where/from where the fax was sent, and if it was successful. Any information on the actual fax content is unavailable.
Jun 03, 2009 | Brother Office Equipment & Supplies
Canon i-sensys fax-L100
The machine keeps in memory only reports of faxes sent or received until the page is full.When the report page is full, the earliest fax is removed to make way for the most recent. Therefore if you sent enough faxes after 4 Apr 08 to fill a page, there will be no record.
Aug 18, 2008 | Canon FAX-L1000 Plain Paper Laser
Need fax out of memory
There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Aug 04, 2008 | Lexmark X5470 All-In-One InkJet Printer
Confirmation that a fax went through
How many faxes did you send in the last 20 days. Most Fax Machines only keep 30 - 35 in the journal report if less than that what model do you have and I should be able to help
Apr 25, 2008 | Brother IntelliFAX 1840C Plain Paper...
Print fax journal from previous date on Brother MFC-3820CN
although it may have a time retreival function it will not store 2mo of faxes !! most likely only a few days depending on the amount of fax you receive
Dec 06, 2007 | Office Equipment & Supplies
435 people viewed this question
k24674
jasbo
jasbo
