Maytag-Neptune stopped part way though cycle. Error code 0E shows on LCD panel. Powering down does not reset. I can't enter service mode as described in the washer manual the 0E code remains.
    Problem Solver:
  • 12 Answers
In general this error code is the main control.
Resetting by pulling out the plug may help, but I wouldn't count on it.
This would require a new main control board.
Posted on May 14, 2009
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Reset Error codes
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Maytag Nuptune... when it reaches the spin cycle, it spins, reverses direction spins , then stops. I push the start button and once again it goes through the one spin and reverse and stops again
""when it reaches the spin cycle, it spins, reverses direction spins""
So I understand do you have the washer top raised to view this action? The wash basket rotates one rotation or are you talking about the tumblers?
If you raise the washer lid and rotate the wash basket CCW the Spin direction will it rotate CCW with very little effort?
Any dC or UC error code on fail to Spin?
If you do Spin Only Cycle do you have the same results.
I would enter Service Mode and do the Quick Spin test on page 14 of the Service Manual and see what the results are.
You can get the SM from this forum once you join.
16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error code OE will not finish cycle
Hi
Thanks for using FixYa. A fault is detected in the water level sensor. Data (frequency) shows the water level is at or above the overflow level. Try entering the service mode by pressing the Spin and Temperature keys for three seconds or until the control beeps.
NOTE: The washer must be ‘ON’ before Service Mode can be entered.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Maytag Neptune MAH9700 Front Load Washer
The signal keeps beeping constantly, how can I stop this?
If it’s a FAV6800AW or FAV9800 are there any codes in the console display? Have you tried to recycle power to the machine? If you haven’t already done so disconnect the 120VAC power plug on the machine and reconnect after 10 seconds this is a hard reset to the machine Control Board. Does it still beep when you try to start a cycle?
Lets see if we can get into the machines Service Mode.
This is from the FAV6800AW/FAV9800AW Service Manual board output test on page 16.
Enter Service mode;
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys simultaneously for three seconds or until the control beeps. The Console display will show “00”.
Access Board Output Test by pressing the Delicates key. The console display will show “ot”
The lid lock will lock and the Quick Wash LED will be lit. Will the machine allow you into Service Mode?
If not have you recent storm activity in your area and do you have surge protection on the 120VAC outlet powering the washer?
Report back and we will go from there. Rich
Jul 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
Getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
Maytag neptune washer stops after filling with water on the first cycle...will not spin Neptune stops after filling. No codes. Lid unlocks. Ideas?
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune mah5500b washer will not go into final spin
most likely a code is stored in the computer as it probably encountered an error getting up to speed. this would probably be in the motor control board on bottom not the main control on top. main control will have the error though. tech sheet should be located in base of machine on side wall remove rear panel and look to left. this will tell how to access diagnostic mode and retrieve code.
Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
