Question about HP w1907 LCD Monitor
Lcd monitor will turn on for about 2 seconds then go blank.
I have hooked the monitor up to different computers and i have the same problem. The screen comes on and looks perfect for about 1-2 seconds then goes black. If i shine a flashlight directly on the screen i can see that the computer's display is still there just very dim. i have messed with the settings and nothing. i am assuming that it is the inverter board from alot of other posts that i have read... i took the computer apart but could not tell what was actually damaged or needed to be fixed. the monitor is an hp w1907 could someone help me along with maybe where i could find a new inverter board or how to fix the one in the computer?? any information would be greatly appreciated.
    Novelist:
  • 152 Answers
Butterx99, First thing you should do is surf the net for pics of swollen electrolytic filter capacitors. You will find many, many examples. You will also need to inspect both the switch-mode-power-supply and the inverter boards for failed thermally cracked (fractured) solder joints. I will try to attach a pic of what you would be looking for. You hav failed to mention how many printed circuit boards are in your monitor. Some have only 2, others have 3. If only 2, then the "inverter circuit is part of the SMPS board. Did you take pics so that you can remember where everything goes when you need to reassemble? Let me know by email if you don't get a the pic through fixya. Bye for now. I'm louie12fix on fixya or lmistyrel@aim.com
Posted on May 14, 2009
    Sergeant:
    Champion:
  • 225 Answers
Good morning! possibly the hardware is having trouble powering up the panel/ccds and it should be replaced/serviced according to the terms of the warranty, I suggest to bring it to an HP authorized service center, best regards
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor displays for about 2 seconds then screen goes blank. switching monitor of and back does same 2 seconds the blank screen. tried on 2 different computers , problem still persists any clues thanks
The problem can be caused by bad caps (bulging or leaking) in the power supply, bad inverter back light circuits, or worst case will be lamps. Look for bad caps first since it is easy to see, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Most monitors will fail after 2 years.
Feb 22, 2010 | Belinea (101705) (Gray) 17" LCD Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Monitor totally blank
You have a power supply issue. Something is causing teh supply breaker to trip. You will need to find a local repair shop to pin point the issues.
Oct 03, 2009 | HP w1907 LCD Monitor
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen STAYS BLANK
check your system unit to make sure the problem is not from the system unit
the signal stage and cable is more likely to have faults contact a local technician for confirmation
Nov 27, 2007 | Star Logic 17" LCD Monitor
HP w1907 LCD Monitor Logo
987 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
