Question about Air Innovations Ultrasonic Digital Humidifer with Digital Display - -
Waterless code displays, but it is full
Says it is waterless, but unit is full
    New Friend:
The inlet valve spring is too strong on these, so the water can stop flowing into the unit. makes sure it is on a flat surface, fiddle with the valve spring.
Posted on Nov 16, 2014
  • DCTracy Dec 09, 2015
    Pete's right-- just jiggled the bar thing (techinical term) and voila! waterless icon turned off.
SOURCE:
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
Unit does not turn on
I am having the exact same issue after cleaning the unit, it doesn't start; no light indicator at all. Anyone has a fix or recommendations?
Nov 14, 2013 | Heaven Fresh HF 707 Digital Ultrasonic...
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
WATER LEVEL FLOAT DEVICE PREVENTS UNIT FROM TURNING ON,EVEN THOUGH WATER TANK IS FULL. REMOVED SOME FILTER MATERIAL WITH NO EFFECT. FLOAT IS FREE WITH NO RESTRICTION.
These hints are from the air o swiss webpage.
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
If your issue is with the float and not the mister, then you have to make sure the float is tripping the micro switch that turns the machine on. Some units the filter will not allow the float to hit the switch if the filter is not installed correctly. If everything is in correctly and the float is tripping the switch, then the micro switch must be faulty.
Apr 04, 2011 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
No more steam. Want advice on disassembly.
There is info on the FAQs from Air-o-Swiss:
http://www.airoswiss.net/service/faq.aspx#35
Q: Unit is running intermittently.
A: How long has it been since the contents of the cartridge were replaced? If 2-3 months have passed, it is time to replace the contents of the cartridge. However the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit ceases operating at its full performance. If the contents of the cartridge were just replaced there are probably too many granules in the cartridge. Remove 2 tablespoons of granules from the cartridge.
Feb 20, 2010 | Air-O-Swiss U7142 Humidifier
I would like to solve the problem of droping water from the air conditioning units instaled outside windows of my apartment. To avoid this problem a canalization should be mounted up to down of the...
in our school building, there are 2 air con. units per room.. we also have 3 floors which has approximately 30 rooms per floor.. what i observed is that they put a hose from where a basin-like is installed so that when water leaks, it goes to the basin just under it then through the hose down straight to a canal.. besides, a hose is extendable, there are no limits which is why it's good for buildings too.
Jul 08, 2009 | Sunbeam Health at Home Waterless Vaporizer...
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
Air Innovations Ultrasonic Digital Humidifer with Digital Display - - Logo
2,049 people viewed this question
Top Air Innovations Humidifiers Experts
 alejandro
alejandro
Level 1 Expert
Tom Chichester
Are you an Air Innovations Humidifier Expert? Answer questions, earn points and help others
