Question about RCA HD50LPW164 50" Rear Projection HDTV
Fan for bulb making loud noise
The Fan that is behind the replaceable bulb is making a really loud noise.  Took the TV in for repair, it is out of warranty.  Shop said it is was the color wheel?  I looked at it myself, seemed to be the fan that kept the bulb cool.
  • 1 more comment
  • derrick grifin Nov 26, 2007
    have a loud "whining" noise in the area of the fan for the bulb. The bulb does not light when this happens ( the bulb is new ). In a few minutes, the sound goes away and the picture comes in perfect. A few minutes later, the picture fades, the sound reappears and the screen turns black. The tv was bought brand new one and a half years ago. What causes this?
  • bigjon61 Aug 06, 2008
    I had honest technician tell me that it is the motor (bearings go bad) for the color wheel that makes that awful whining noise. He also said that the motor assembly costs $800 and that it is hard to find. I agree with another complaint that said RCA should be held responsible for this problem with some legal action to be taken if they balk.
  • thedeyoungs Feb 06, 2009
    I'm having the small problem. Hard its to get a color wheel and then replace it.
This is 98% your color wheel. This coming from the TV repair shop. I have the same issue, and I'm trying to find a color wheel now. noone seems to have onein stock. I'm trying to find someoene to rebuild the one i have.
Posted on Feb 19, 2008
The fan that is behind the bulb is making a loud noise for a few minutes and then the noise stops. We tried spraying the fan with WD40. ?? We can't seem to find a way to remove/replace this fan. Can't...
sometimes dust accumalates on fins of fans and causes rotation to deform and gets fan off balance causing noise .Also heat from lamp causes deformaties on fan and causes fan bearing to make noise.These fans can be replaced fairly easily
Jul 30, 2009 | Akai PT50DL24 Television
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
Broken edge of bulb- TV won't work
The color wheel was the cause of the loud whining noise. The only item in the set under pressure that could possibly pop is the lamp. The fact that you have the 3 lights on is the lamp failure indicator. The lamp driver or ballast can also fail and give the same light error but I have never had one to pop.I would replace the lamp for sure. Also the lamp as you know sits right in front of the color wheel so perhaps it popped and fragments of the lamp ended up on, near or around the color wheel
Jan 11, 2009 | Samsung HL-R6167W 61" HDTV
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
Loud noise from tv
if this is a very annoying screeching or sqeualing type sound, it is, in my experience, the "color wheel" which is located inside the lite engine. this is a replaceable component whick costs about $110....i've done this repair many times with no problem....
Oct 30, 2007 | RCA D44LPW134 44" HDTV
Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Sep 11, 2007 | Windchaser PACR10 Portable Air Conditioner
Televison & Video Logo
222 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
