Question about Craftsman 4 Cycle Blower/Vac
Need to replace gas line on Sears Craftsman 2 cycle blower
Line disentegrated and I need to replace
  • 246 Answers
Hello pgtoepel:
The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
1998 EL Falcon right Hand rear brake wiring loom, light socket disentegrated
It's a 98. Call around and see if you can get the plug. Parts stores, junk yards. If you can't find it. Go with a newer year. Modify it to fit your lens. May have to modify the lens also.
Jul 14, 2016 | Cars & Trucks
Tip
To simplify what this guy is saying. I recommend getting new thermal compound...
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
on Oct 17, 2008 | Toshiba Satellite A135-S2276 Notebook
The soles of the shoes disentegrated of Stonefly shoes
It is possible to repair these shoes and put a new sole on at a shoe repair shop.
Feb 11, 2014 | Stonefly Clothing Accessories
You can get these repaired at a shoe repair shop. Replacement soles can be put on and the shoes will be as good as new.
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
I have a craftsman blower /vacum 29cc 4 cycle 425 cfm ? would like to know if you use 2 cycle oil in the gas or is this a gas only unit , second question is there is an oil port on the back of the motor...
Hi lindseyhpaint...
DO NOT MIX OIL WITH GAS ON A FOUR CYCLE ENGINE use gasoline only, the oil will go into the oil port on the back of the motor with an oil level line (crankcase).
You will need a good grade of 10W30 to use in the crankcase.
Please take time to rate me
Aug 30, 2011 | Garden
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
I NEED TO REPLACE THE STARTER CORD ON MY CRAFTSMAN GAS LEAF BLOWER MODEL NO. 358-797180
Try Sears...They sell/have appl. parts. You'll be amazed at what they have.
Apr 21, 2011 | Craftsman 25cc Gas Line Trimmer
I would like to download the manuel for the craftman 5hp snowblowermodel # s247.996640
The model number of your snow blower is actually 247.886640. That's why nobody else could figure where to get your manual.
Here is the link to the manual:
http://www.managemylife.com/mmh/owner_manuals/25129/CRAFTSMAN-Snowthrower-Gas-L0308228?brand_name_search=247.886640
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Dec 28, 2010 | Garden
Craftsman 4 Cycle Blower/Vac Logo
340 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
