Question about Garden
Have old Eager ****** 280 Gas Trimmer, Replaced Gas line, cleaned filter, tubing and Primmer Pump return line, still won't Prime, and start engine. Pust some gas in spark plug, engine run for a few seconds. No Gas being sucked into carburator. Help! Joe
  • 323 Answers
If the bulb is good and it still won't prime, then you have either one more tube (there are usually 3) to replace, OR, the gas pickup in the tank has a plugged filter or a plugged line. I'd check it first.
Sirwriter
Posted on May 14, 2009
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Featherlite primmer button won`t work. put new gas lines on and they are open, still when I push the primmer it draws no fuel and won`t respond back as if it has a vacume holding it compressed?? can you...
If there is a blockage in the fuel sysstem the bulb will not return, check the fuel filter in the tank, check the fuel hoses are not kinked, if this does not help the blockage will be in the carb itself.
Jun 15, 2011 | Garden
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Changed fuel line on my troy-bilt gas trimmer wichone goes where
the fuel thank have 2 lines the one is close to you facing out is the pick up line this line has a fuel filter inside the tank, thats mean go thru the carburator or adapter coupling thru the carburator in the bottom. The second line is the return line this line go thru the prime valve on the bottom and the top line go thru the top line tube in the carburator.
Apr 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
String trimmer, fuel lines disintegrated, I need routing.
The Walbro has two connections on it for the fuel line. My Walbro has one connection on the side of the idle screw and main fuel adjusting screw. This connection hooks up to the suction side of the primer bulb. Usually the shorter stem. (You actually **** fuel through the carb instead of pushing it through.) On the other side of the carb is the other hook up. It draws fuel from the tank. This line will connect to the side of the tank that has the filter. The other side of the tank is your return and it hooks to the other connection on the primer bulb. Usually the longer stem.
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Prime bulb need replaceing
Buy a replacment primmer assy. One tube on the primmer is longer make a note where it goes...the one thats sucks (Inlet) goes to the carby return side.
Nov 25, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
