SOURCE: EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
SOURCE: waste ink pad is saturated how can i reset
You can also try dabbing the waste pad with absorbing paper. This worked for me.
