Question about Samsung CLP-500 Laser Printer
CDT Sensor where is it?
I got diagnostic CDT calibration repair, The manual says this means the CDT Sensor has dust on it, but it doesn't tell where the sensor is located to I can get to it. Can you help me?
  • 1,006 Answers
Here is it USER MANUAL WHERE IS LOCATED CTD SENOR
http://www.usersmanualguide.com/samsung/printer__color_laser_printer/clp-500
Posted on Oct 15, 2007
SOURCE:
Diagnosis code ppu84172
Hi, Johnny 84172 is not an error code it is the current PPU (pulses per unit) number that has been downloaded to your ECM and is used to calibrate your speedometer. If you change tire size and or gearing your speedometer will become inaccurate and you need to recalibrate the speedometer, this can be done at your local Harley dealer or you can go online and purchase a calibration tool that is plug n play for around $100 there is a difference between stock EFI calibrations that may be causing some of the speed signal related issues you encounter. The stock calibrations for 2004 & later model years will write a PPU Value to the ECM. The current stock calibrations for 2003 & earlier models do not. The PPU Value is what controls the speed displayed on the speedometer, which in turn controls the turn signal cancellation. If you have downloaded a 2004 & later stock calibration into an ECM it should not be used on a 2003 or earlier motorcycle; the speedometer and turn signals will not function correctly even after updating the VIN and calibration to match the vehicle. SPEEDOMETER TROUBLE CODES - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - speedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Diagnostic Code PPU 84172 on Dyna Harley Davidson Forums Harley Davidson Dyna Glide Twin Cam 88 Service Manual
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/harley-davidson-dyna-glide-owners-manuals
Instant Repair Help over the Phone to speak to me personally $4
Oct 09, 2018 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Can you tell me the location of my neutral safety switch on my 2008 Ford F2 50 super duty super cab 5.4 L engine automatic transmission
It's not called neutral safety switch .
Transmission Range (TR) Position Sensor Assembly
The transmission range (TR) position sensor assembly is an internally mounted sensor that includes the detent spring, rooster comb and bracket, located next to the solenoid body. The components of the TR position sensor are factory adjusted to each other and the sensor must be installed as a calibrated assembly. The TR position sensor contains electronic circuitry that provides the PCM a fixed frequency at a duty cycle for each of the various positions of the manual lever (PARK, REVERSE, NEUTRAL, DRIVE, M3, M2 and M1) to the PCM. The PCM uses the TR position sensor signal for engine functions (start, reverse lamps) and for line pressure control, shift scheduling and TCC operation.
Your best bet , take your vehicle to a qualified repair shop or Dealer .
Diagnosing an electronically controlled automatic transmission is simplified by using the following procedures. One of the most important things to remember is that there is a definite procedure to follow. DO NOT TAKE SHORT CUTS OR ASSUME THAT CRITICAL CHECKS OR ADJUSTMENTS HAVE ALREADY BEEN MADE. Follow the procedures as written to avoid missing critical components or steps. By following the diagnostic sequence, the technician will be able to diagnose and repair the concern the first time.
On-Board Diagnostics with Scan Tool
NOTE: For detailed instruction and other diagnostic methods using the scan tool, refer to the tester manual and the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
These quick tests should be used to diagnose the PCM and should be carried out in order.
  • Quick Test 1.0-Visual Inspection
  • Quick Test 2.0-Set Up
  • Quick Test 3.0-Key On, Engine Off
  • Quick Test 4.0-Continuous Memory
  • Quick Test 5.0-Key On, Engine Running
  • Special Test Mode
    • Wiggle Test
    • Output Test Mode
  • PCM Reset Mode
  • Clearing DTCs
  • OBD II Drive Cycle
  • For further information on other diagnostic testing features using the scan tool, refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual. Other diagnostic methods include the following.
    • Parameter Identification (PID) Access Mode
    • Freeze Frame Data Access Mode
    • Oxygen Sensor Monitor Mode
    • P0706 TR Sensor TR sensor frequency fault detected. TR sensor signal frequency is out of normal range. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H . P0707 TR Sensor TR sensor circuit duty cycle low input. TR sensor signal duty cycle is below threshold, sensor/circuit electrical malfunction. Only REVERSE, NEUTRAL and 5th gear detected. Engine may not crank. For gasoline engine vehicles, Go To Pinpoint Test C . For diesel engine vehicles, Go To Pinpoint Test H .
Jul 25, 2018 | Ford Cars & Trucks
What does fuel control sensor is out of calibration mean?
have a read
' Repair Guides ' Diagnostic Trouble Codes ' 3.3l V6 Vin A Std 1 ...
https://www.autozone.com/repairguides/Nissan...05/.../_/P-0996b43f80376bd1
Trouble Code: P0171. Fuel Trim Lean (Bank 1). Possible Causes: Air leaks after the MAF sensor, or in the EGR or PCV system. Base engine "mechanical" fault affecting one or more cylinders. Exhaust leaks before or near where the front HO2S is mounted. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAP).
' Repair Guides ' Diagnostic Trouble Codes ' 2.7l L4 - Std 2 ' AutoZone ...
https://www.autozone.com/repairguides/Toyota...06/.../_/P-0996b43f80378cd5 Base engine "mechanical" fault affecting one or more cylinders. EVAP system component has failed or canister fuel saturated. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAF). Fuel delivery system supplying too much fuel during cruise or idle periods ...
' Repair Guides ' Diagnostic Trouble Codes ' 3.0l V6 Vin H Std 1 ...
https://www.autozone.com/repairguides/Mitsubishi.../_/P-0996b43f80379593 Fuel Trim Fault (Bank 1). Possible Causes: Air leaks after the MAF sensor, or in the EGR or PCV system. Base engine "mechanical" fault affecting one or more cylinders. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAP). Fuel delivery system supplying ...
' Repair Guides ' Diagnostic Trouble Codes ' 2.7l L4 - Auto 2 ...
https://www.autozone.com/repairguides/Toyota...06/.../_/P-0996b43f80378cbc Base engine "mechanical" fault affecting one or more cylinders. EVAP system component has failed or canister fuel saturated. Exhaust leaks located in front of the A/FS or HO2S location. Fuel control sensor is out of calibration (i.e., ECT, IAT or MAF). Fuel delivery system supplying too much fuel during cruise or idle periods ...
Auto-calibration method for a wide range exhaust gas oxygen sensor
https://www.google.com/patents/US6227033
An improved fuel control in which the transfer function of a wide-range exhaust gas oxygen sensor is automatically and periodically learned or re-learned in the course of vehicle operation. The oxygen sensor is calibrated at two different operating conditions: at a stoichiometric air/fuel ratio, and at a fuel cut-off or free-air ratio ...
Mar 06, 2018 | Cars & Trucks
2002 Electra Glide reads do1clr?
Hi Manuel, if you have a 2003 or older Harley Davidson here is how you can access the Diagnostic Fault Codes through your speedometer.
The reset switch is used to change the odometer display between mileage and trip values and to reset the trip odometer. It is also used to identify the speedometer calibration and to enter the diagnostic mode, clear diagnostic codes and exit the diagnostic mode.
The Diagnostic Mode is entered by holding down the odometer reset button with the "off/run" switch in the run position, turn the ignition from OFF to ON and wait for the fuel pump to stop priming then let go of the reset button. The normal power-up sequence will occur and before entering the diagnostic mode diagnostic codes set during this power-up sequence will be stored as well. When in the diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
There are 7 different diagnostic codes available:
d01 - Speed sensor power output shorted low
d02 - Speed sensor power output shorted high or open
d03 - Not Used
d04 - Not Used
d05 - Speed sensor return shorted high
d06 - Speed sensor return shorted low
d07 - Not Used
d08 - Speedometer power over voltage
d09 - Speed output shorted high
d10 - Speed output shorted low or open
CAL XX - Speedometer application calibration number:
14 = Domestic
15 = HDI
When in the diagnostic mode, all codes are displayed in sequence from d01 to d10.
As a code appears in the display (for instance d02), it will read
"d02Set" if set or "d02CLr" if clear.
You can exit the diagnostic mode by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
Diagnostics cannot be performed if system voltage is less than 9 VDC or greater than 16 VDC. The only exception is d08 which is set when system voltage is greater than 16 VDC.
After all the diagnostic codes are displayed, the speedometer
Calibration number is displayed example CAL 14 if you change rear wheel size or gearing you need to visit your local Dealership to have your speedometer recalibrated.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Harley Davidson FLHTCUI Ultra Classic Electra Glide 2002
Harley Davidson Touring Models Workshop Service Repair Manual 2002 $9 very cheap
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak with me personally absolutely "FREE"
Apr 13, 2017 | 2002 Harley Davidson FLHTCUI Electra Glide...
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
2000 Harley Davidson FLHRCI Road King Classic cal 03
Hi Anonymous, if you have a 2003 or older Harley Davidson here is how you can access the Diagnostic Fault Codes through your speedometer.
d03 - Not Used
d04 - Not Used
d07 - Not Used
14 = Domestic
15 = HDI
Calibration number is displayed example CAL 14 if you change rear wheel size or gearing you need to visit your local Dealership to have your speedometer re-calibrated.
2000 road code d08set cal 03
2003 Harley Touring Service Manual pdf
2005 Harley Davidson Road King Classic EFI Owner Manual
Jul 14, 2014 | 2000 Harley Davidson FLHRCI Road King...
We have a VReader and the touch screen doesn't
Try calibrating the touch screen (means of doing this can be found in the user manual). If, after calibrating the screen the touch screen is no longer responsive, I'm afraid that the screen is "ka-put" and will require a repair or replacement.
Jun 24, 2013 | Cell Phones
MY TROUBLE LIGHT IS STAYING ON
2000-2004
The Diagnostic Mode is entered by turning the ignition from OFF to ON while holding the reset switch in. The normal power-up sequence will occur before entering the diagnostic mode. Diagnostic codes set during this power-up sequence will be stored as well.
Important Note: Be sure no diagnostic codes are indicated before reset is held in for more than 5 seconds or diagnostic information will be lost.
When in diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
There are 7 different diagnostic codes available. They are as follows:
d03 - Not Used
d04 - Not Used
d07 - Not Used
14 = Domestic
15 = HDI
As a code appears in the display (for instance d02), it will read "d02Set" if set or "d02CLr" if clear.
The diagnostic mode is exited either by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
After all the diagnostic codes are displayed, the speedometer calibration number is displayed (CAL 14 for example).
Jun 12, 2009 | 2000 Harley Davidson FLTR-FLTRI Road Glide
CDT Calibration Error
CTD (not CDT) stands for Color Toner Density Error. Your bad sensor is not on the printer, but on one of the color toners.
Oct 15, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
553 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
