Question about Dell Inspiron 9100 Motherboard - N4878 CD-ROM Drive
Keyboard and mouse failure
I have an XPS 400 and my usb ports wont read anything
    Sergeant:
  • 199 Answers
Your usb ports does not work or it has a problem it is not connect with pc.if windows 98 then it is required driver.
Posted on May 17, 2009
I have a dell dimension 5150. I was attempting to upgrade drivers, and appear to have lost use of keyboard and mouse usb ports. As I cannot do anything on computer without one or other, its impossible to...
Are your devices wired or wirelss ? Have you tried another usb keyboard ? You could try booting up the machine, then switching the devices to another usb port and hope windows will reconize them. Last resort would be getting a real PS/2 keyboard at thrift store or if your really stuck, boot with a live-CD then you should have mouse and keyboard to try to copy drivers manually over to the windows folder.
Sep 29, 2013 | Dell Dimension XPS 400 PC Desktop
Laptop Model : Dell XPS 1530 i think i m having some problems with the usb power issue. Problem 1: when i connect an external hard drive which have bigger capacity than 120gb, the power of the usb will...
It sounds like the motherboard is causing the usb ports to malfunction by allowing power surges into the power input to the ports.You maybe should try a powered usb hub to power your hardware or you may face motherboard replacement
Jan 10, 2011 | Dell XPS M1530 Laptop
My USB mouse does not work I've tried using 3 different ones, My keyboard works fine in same USB ports
make sure the mouse lead is seated correctly and is not faulty also
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Nov 30, 2010 | Dell Dimension XPS 400 PC Desktop
Wireless mouse and keyborad will not work. replaces batteries and hit reset button on mouse and keyboard. can not get access to computer
Sounds like your USB circuit may have gotten fried due to a static discharge (assuming your keyboard and mouse are USB). You can purchase an "add-on" USB pci card or a PS2 Mouse and Keyboard.
Feb 01, 2010 | Dell XPS 400 PC Desktop
When I turn on my computer,(XPS 400) I get the black dos screen as it goes through the booting process - it says "Keyboard Failure" and then continues on to my Windows login screen. I then cannot use my...
first make sure the keyboard is plugged in all the way. then make sure there isn't a button stuck on your keyboard all else fails wal mart has some cheap ones if it STILL presists. your PS/2 port may be messed up unless your using usb
Oct 21, 2009 | Dell XPS 400 PC Desktop
Dell XPS 400 no power to usb
Cant remember the exact location for this, but you need to access the CMOS config when starting up. Dig around a little and you will find the settings that will allow you to start you system with a usb mouse and keyboard.
Hope this helps. If you have any idea where I can get drivers for my motherboard (EPoX EP-4PDA5) that would be great. I already tried EPOX's website, and no joy.
Cheers
Jan 08, 2009 | Dell (002TR) Motherboard
Dell XPS 400 no power to usb or pci slots
I have had the same problem with my dell xps 400. What I did was purchased a usb power hub and that solved the problem for me. SAved me from buying a new mother board.
Sep 09, 2008 | Dell (002TR) Motherboard
Its a Dell XPS 400
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Feb 19, 2008 | Dell Dimension XPS 400 PC Desktop
Open Questions:
USA:AOL@ 1~866:201:6261 password reset CONTACT AOL Tec*h SuPp0Rt 24/7geniusmad*! Here USA AOL MAIL Tech support phone number help provide by AOL MAIL technical regarding your Issues call I~866~201 6261.AOL MAIL customer service phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL SUPPORT phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL tech support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Technical support phone number I~866~201 6261USA\CANADA AOL MAIL customer support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number
Jan 20, 2018 | AOL Computers & Internet
See all Dell Inspiron 9100 Motherboard - N4878 CD-ROM Questions
Computers & Internet Logo
135 people viewed this question
Alun Cox
